Drag Racing Tech
6 speed drag racing tips
Old 07-17-2011, 11:20 PM
  #101
studderin's Avatar
hell yhea tim!!! I love your car, your pinks was on the other night, had it setup to record pinks still. I htink they showed 4? I watched yours 2 times then worked on my car a ton this weekend
451whp is is big deal for those parts. The heads got the legal stuff dont, there not factory stock right?
you broke off the front airdamn?
Old 07-17-2011, 11:24 PM
  #102
Zmg00camaross's Avatar
Originally Posted by studderin
I know someone that painted there stock bell housing black if tech ever looked under the car. But now with a dual disc clutch I see alot more stuff to come apart....
I figure the quicktime weights more then stock. anyone know about how much??
I worked on some older cars with poor fitting bellhouseing..2 starter spots, chevy, and BOP patterns. I hate that stuff, I want aftermarket parts to be better then stock.
My quicktime fit just like stock if that helps. I should have weight it but is heavier for sure.
Old 07-18-2011, 06:48 AM
  #103
BADD SS's Avatar
mine fit better than stock, the dowel locations were tweaked on the stocker, the quick time slides right on. It's alot heavier studderin, but worth it... I think it weighs 21 lbs.... stocker is like 5.
Old 07-18-2011, 09:07 AM
  #104
Race your car!
JL ws-6's Avatar
The weight of that bell housing, vs having stuff come through the floor at you... I wouldn't care if it weigh'ed 100 lbs it would still go in the car.
Old 07-18-2011, 11:49 AM
  #105
TOSTO RACING's Avatar
The inner fender well came out do to the car slamming down so hard the 1 2 shift is hard in the air the next pass was alot better lol. I did have a valve job done on the heads but no porting is allowed I do also have the stock valves so it's close to cam only
Old 07-18-2011, 02:40 PM
  #106
studderin's Avatar
Ya, I have marks on mine form my 26 DS2s. You running 28s tim?
cool on the heads,
Old 07-18-2011, 06:10 PM
  #107
I would agree, did go on easy. Love how the dowels stick thur the bell.
Old 07-18-2011, 06:11 PM
  #108
27.5 m/t's
I'm suprised none of you guys have been in the 9's cam only yet with a stick. its a tall order ,but it could be done.
Old 07-18-2011, 06:24 PM
  #109
studderin's Avatar
Old 08-18-2011, 10:54 AM
  #110
nocooler's Avatar
Can you guys point me in the right direction.......
Car would dead hook with stock internals @ 6200rpm (then bog)
When I change the trans (RPM level 4) I found the slip yoke had twisted splines, so I installed a strange chromoly unit.
Since I added heads and cam - I can't dump the clutch on the 2-step above 4000 without massive wheel spin. Looks like a bounce/spin to me. Quick slips kind of work - maybe I just need more practice.
Tires are 26x11.5x15 ET Streets no tubes and a lot of passes on them - 12psi
4.11 Gears - 9" rear
Monster Level 3 clutch - Quicktime bell - Tick hydraulics
Lowers are in the stock holes
MWC short torque arm one hole down from the top (3rd hole up)
Pinion angle 1.5*
Spoon Drag bar
Front SA QA1's set at 1
Rear DA QA1's set C-12 R-12
I'm wondering if the tires are done - they are still sticky enough for them to pull the rpm's down in the burn box, but maybe the sidewall is wore out??? The have easily 150 passes on them - thread looks good still. I'd hate to buy tires right now and not have it help.....or should I just go 26" MT Drag Stiff walls or change the gear and go 28"s?
Car went 1.65's last night slipping the clutch @ 5500ish without the 2 step. As soon as I add the 2-step to the mix (WOT) and let the clutch out it's spin city.
I'll get some video up tonight - and slow it down.
Any thoughts would be appreciated.
Old 08-18-2011, 12:23 PM
  #111
Mikey 97Z M6's Avatar
Here's what I came up with:
Stock Bell: 8.4lbs
Quicktime Bell: 22.8lbs, Engine plate, 2.8lbs. Total: 25.6lbs
Mike
Old 08-18-2011, 12:35 PM
  #112
Not familiar with the QA1's, so where are the adjustments at in the range? Are they maxed out or is there more left? I'm assuming the negative means stiffer, no?
The slo-mo vid will tell you a lot on what the suspension/chassis is doing and what it needs. If you're getting tire bounce on the hit, it'll need a lot more compression and rebound. Hopefully the QA1's have enough valving.
Mike
Old 08-18-2011, 12:41 PM
  #113
nocooler's Avatar
Mike
Mike thanks for the response - the slow mo video does still show a bounce.
The QA1's range from 1 to 24 and are currently at 12 for both compression and rebound. (sorry for the confusion with the dash) So I can tighten them up 12 more clicks. Sounds like I should take them up 6 more clicks and try them there.
Old 08-18-2011, 12:56 PM
  #114
Yeah, def tighten up the shocks but remember it's possible to go too stiff on the settings as well. Can you tell about how much extension you're getting? Post up a vid if you can. The driver side rear 1/4 view is best.
Mike
Old 08-18-2011, 01:10 PM
  #115
nocooler's Avatar
Mike
I'll get a video up later - it doesn't look like a lot of extension, maybe 2 inches or so. As long as I know that taking them tighter should help - I'll move in that direction.
Thanks
Old 08-18-2011, 05:19 PM
  #116
nocooler's Avatar
video is all washed out from the lighting - I tried to adjust it but it makes it worse. You can see it hit the tire, then the tire bounces, and unloads.
uploaded it anyways:
http://www.youtube.com/watch?v=ClCPWoUKVV8
Old 08-18-2011, 07:41 PM
  #117
Extension doesn't look horrible, I'd start with 2 more clicks on the rebound and 4 more on compression.
What editing software are you using for slow motion?
Mike
Old 08-18-2011, 08:01 PM
  #118
nocooler's Avatar
Mike
Thanks Mike - I'll give that a go.
Apple iMovie
Old 08-19-2011, 12:49 PM
  #119
WheelsUp84z's Avatar
my car used to do the same thing yours does. I'm at 16 clicks compression and 8 rebound. I found that the slower rebound doesnt let the rear unload as fast, Also on the fronts i have the extension 4 clicks from full loose and compression 4 from full tight, which will keep the nose from settling and also from unloading the tires as fast. If i could dial the suspension to do better this is all I can really do to keep it the weight transfer to the rear. I still have too much wheelspin, but it keeps the 60's in the low 1.5x's on a TNT night, which is decent for a 37xx lb car,
http://www.youtube.com/watch?v=_zeO4DnLBBU
Old 08-21-2011, 01:13 PM
  #120
nocooler's Avatar
Tried it today with the shocks @ 15 compression and rebound 9. Car came out spinning to a magnificent 1.7x 60' - with 15psi in the tires, tried again with 12psi in the tires and the same crappy 60'. Went back to 12 compression and rebound 8 - same thing just spun the whole way through the 60'
1st 2 launches were at 5000rpm quickly letting the clutch out and the 3rd was a 5000 rpm dump. No 2-step today.
No video - I was solo today.
I was going to get drastic and change the lower control arm angle - but found one of my screw in studs had backed out and bent....I called it quits.
Shock changes aren't making a huge difference - maybe the tires are just done......time to go 4.56's and 28" stiff walls?
Quick Reply: 6 speed drag racing tips
