Drag Racing Tech
MSD 2 Step Wiring question.
Old Jul 7, 2016 | 08:08 PM
6spdg37s's Avatar
Originally Posted by Nitroused383
Just adjust the switch at the pedal further away so it's not at the very top. It's a pain to crawl under there but it's threaded quite a ways so put it where you like.
I really want it to turn the 2 step off as soon as I come off the pedal the tiniest bit. which is why I want to do it off the switch that controls the starting as it is much shorter.
Old Aug 31, 2016 | 05:12 PM
6spdg37s's Avatar
Played with the wires under there for the one that tells the pcm the clutch is depressed to start and it doesn't work so now I have to play around more and figure this out
