Drag Racing Tech
Powershift with a 2 step ??
Old May 18, 2011 | 09:18 PM
1nastyss's Avatar
Default Powershift with a 2 step ??
I'm wanting to go with the msd 2 step, just want to know if there are any problems powershifting with it, any particular way you have to wire it? Let me know fellas
Old May 18, 2011 | 10:42 PM
WhiteLTone's Avatar
if you wire the two step up to a button on the steering wheel, say a momentary contact button that is on when pressed, the two step will only be active while holding the button therefore as long a your not hitting the button while going down the track it will have no effect on anything.
Old May 18, 2011 | 10:46 PM
Zmg00camaross's Avatar
Since your a M6 I would hooked it to the clutch switch and works great that way.
Old May 19, 2011 | 06:45 AM
SlickVert's Avatar
After the launch the 2 step does not have any more function. Your rev limiter will be the high rpm limit when you are power shifting.
Old May 19, 2011 | 07:39 AM
jmm98LS1's Avatar
MSD two step here and no problems power shifting. I wired mine to the starter safety switch, so when you power shift and just stab the clutch quick the pedal doesn't go down far enough to trigger the 2 step.
Old May 19, 2011 | 07:27 PM
1nastyss's Avatar
Gotcha , thanks fellas
Old May 19, 2011 | 08:08 PM
studderin's Avatar
LPE on the clutch switch. works great WOT
