MSD 8733 2-step problem
Hooked up the coil harnesses, fired it up. Nothing.
Verified 12v to the power wire when switch activated.
Funny thing, with neither wire hooked up, just the coil harnesses, the LED on the 2-step is on.
Did I get a bad unit or am I doing something wrong? Thanks for any tips!
"The LS 2-Step has a built-in rpm drop circuit that prevents the low rpm limit from activating during
gear shifts (when connected through the clutch switch). In order for the limit to activate, it must see
an rpm drop of more than 1/3 the set amount. For example, if the limit is set at 3,000 rpm, the limiter
will not activate unless it sees more than a 1,000 rpm drop."
"CONFIRM INSTALLATION
With the power On, engine running, activate the clutch or On/Off switch. If connected correct, the
LED will illuminate when the clutch is activated. To verify the rpm, set the limit at a lower rpm, such
as 3,000, and test the system. "
One thing I'm not sure about: I expected AFR weirdness but since it cuts spark rather than fuel I expected overly rich readings. I'm getting lean instead. I assume that's normal but it seems bass-ackwards. Not sure how much risk in being overly lean for a few seconds at the start of a run?
