Drag Racing Tech
help returning GI
Old Feb 27, 2004 | 06:19 AM
slick rick's Avatar
Default help returning GI
I am returning after a 1 year deployment in iraq. i have 8000 dollars to spend i have a 2002 collector TA it has hooker long tubes true duals, lid and filter, 4.10s in stock 10 bolt, 6 speed The mods i want to make are as follows 12 bolt with 410s, sphon torque arm, Qa1s, spec stage 3 clutch, thunder racings t rex cam package, maf ends ported throttle body,NX NXL kit with the 120 or the 180 shot jets and a roll cage. Will this get me into the 10s or do i need heads also any info would be appreciated.
Old Feb 27, 2004 | 07:25 AM
Fast SS on TNT's Avatar
You can get into the 10's, but your gonna need a little more. Make sure you get a set of relocation brackets for your 12 bolt (Spohn). You might want to consider also investing in a good set of lower control arms, panhard bar, ET Streets/Hoosier QTP's, and a good drag racing rear sway bar (WolfeRacecraft rock!) Be sure to get a bigger intank fuel pump (255lph) and a hotwire kit. Don't forget a good set of headers, some cutouts as nitrous LOVES a free flowing exhaust.
You can probley hit 10's without everything I mentioned, but a few things will have to be added. Think in term of traction first, then power second. All the power in the world will be wasted on a car that won't hook it up to the track.
Welcome back to the states, and thank you for kicking Saddam's ***!! Booyah!
Old Feb 27, 2004 | 01:50 PM
FastBlackTA's Avatar
here's what it took for me to run my 10.75:
older heads cam package...about 400 rwhp (a little less now due to a change in nitrous systems and setup for a large shot)
hooker lt's
ory, cutout
12 bolt, 4.10's
cartek clutch
28 inch et drags
bmr torque arm
subframe connectors
6 pt cage (to pass tech)
NX wet kit, single nozzle jetted for a 150 hit
warlboro 340 pump
You can easily do it with a cam. If your car is as heavy as mine, you'll need about a 125-126 trap to run in the 10's. I went 10.8 @ 126 as well.
Good luck!
Conrad
Old Feb 27, 2004 | 01:51 PM
btw - watch out with that NXL system, you might wanna look into it before you buy it. I looked into it and eventually decided on the NOS noszle system.
You could easily get away with a NX single nozzle or a TNT kit to do what you want.
Old Feb 28, 2004 | 01:49 AM
slick rick's Avatar
Hey thanks for the feed back and beleive me it was my pleasure to kick some Iraqi ***.
If i get the fuel accumulator i thought the NXL kit was the **** any info?
Old Feb 28, 2004 | 10:52 AM
the problem with the nxl kit is that it just runs off the stock fuel system. so a search on this system, there is plenty of info on it along with some complaints from a bunch of people about low hp numbers. someone else can correct me if im wrong in all this but if you're only going to spray up to a 150 shot (i mean, you could go more i guess but i don think you'll need to to break 10's), i'm not seeing why people need the NXL kit when you can just buy a cheaper single nozzle system and make the same (or more) power and run the same (or better) times.....
thats why i went with the noszle system over the NXL. I built a stand alone fuel low pressure fuel system for it and hit the stock bottom end with a 260 shot (kids, dont try this at home....i'll be backing down to around 200-210 or so for the track to keep it in one peice). I'm not sure if the stock fuel system with a walboro 340 could supply the fuel needed to run these large shots....and i wasn't about to be the first to find out!
any more questions, just lemme know
Conrad
