Drag Racing Tech
afco da front base setting?
Old Jun 19, 2011 | 10:00 PM
Spankie's Avatar
Default afco da front base setting?
What is a good starting point ? My car is in the range of 3300 pounds .383 will be spraying at least 175 out of the hole . Not sure what ifo is need to help decide on a setting new to adj shocks.
Old Jun 20, 2011 | 08:10 AM
Old Geezer's Avatar
maybe middle on both adjustments, video it, look at short times, etc, and adjust from there????
Old Jun 20, 2011 | 10:06 AM
foggedz's Avatar
I would set the compression 4-5 clicks off of full tight, and the extention 7-8 clicks off of full tight. Tight compression helps if you come down from a wheelie. Also at my local track the shut down area is a little bumpy, so it helps keep the front end up when braking hard. If you are looking to do a big wheelie set the extention loose, if you want to keep the front end down at launch set them tight.
Old Jun 21, 2011 | 02:22 PM
ty_ty13's Avatar
7 Second Club
tight on compression and extension would depend on track surface... start 1-2 from middle towards loose.
Old Jun 21, 2011 | 04:04 PM
mm8ls1's Avatar
I went 75% (24/32) tight on the compression with AFCO BNC's and 50% (16/32) tight on the rebound. Pulled the wheels 3 feet off of the ground on a 69 Camaro BBC. I started at 75% comp and 75% rebound and found it way too tight on the rebound. My AFCO DA BNCs had 32 adjustment settings, so I'm not sure what yours have.
Old Jun 22, 2011 | 04:11 PM
foggedz's Avatar
I was told by AFCO to always reference your adjustments from full tight. Just because the chock is still adjusting 32 clicks out doesnt mean that clicks 27 to 32 were actually making a difference.
Old Jun 22, 2011 | 08:28 PM
mm8ls1's Avatar
Foggedz I agree but that is what I used for a baseline. The shocks are only to have 28 clicks for full tight, but u never know about quality control sometimes.
Old Jun 22, 2011 | 08:30 PM
mm8ls1's Avatar
Plus it's all trial and error. It took me about 6 runs to dial in the rebound.
Old Jun 28, 2011 | 04:18 PM
JL ws-6's Avatar
Race your car!
I talked to Eric Staffel from Afco about where to start.. he told me,6 clicks form full stiff on the compression and 8 clicks away from full soft on the extension. That's coming right from Afco, with the BNC front shocks that Burkhart supplied with their front end which I do believe are the same ones that Madman sells, at least that's what Burkhart told me when I ordered the stuff a while back.
Old Jun 29, 2011 | 06:49 AM
MADMAN's Avatar
LS1Tech Sponsor
It all depends on the valving you have in your shocks. You really need to get ahold of who you bought the shocks from. They should be able to give you a tune up and tell you how to adjust them.
__________________
www.madmanandcoracing.com
225-343-9029
