Battery relocate, now will not keep memory.
Standard hook up. positive to switch then to starter. Jumps from starter to main fuse box where factory wire went. Ground to chassis ground. My biggest concern is the computer losing it's "tune" inbetween rounds. Not sure if that is true or not or if open loop it doesn't matter? Thanks for the help.
It's most likly a poorly grounded battery.. or a bad/not big enough wire. I ran 0 ga welding cable, and never, NEVER had any of these problems. Same 0 ga welding cable, was grounded to a stud that was welded onto the back rollbar plate, so I know it's 100% grounded.
What are you using for a battery, and how old is it? I ran a strait over the counter Duralast gold I bought at the local vato zone... nothing fancy. Idid keep a battery tender on it when the car was sitting in the garage fwiw, and ran an ALT on the car that I know was good as well.
I didn't see any real change in the ALT ga either. The ALT has it's own 2 ga wire, that ran to the back of the car strait to the battery. All the power for the car, ran up the 0 ga to the engine bay, and a bulkhead fitting I put in the hvac plate, so that I had a hot power source inside the car for the nitrous controls and whatnot. All the hot wires in the engine bay, were redone. I ran a piece of the 0 ga down to the starter off the bulkhead terminal, and a piece of the 2 ga over to the fuse box. I also grounded the engine with an extra ground wire, and the motor plate also acted as an additional ground (alum, so it's not the best conductor but an additional ground regardless for the block)
I always see alot of people having problems when the battery gets moved... and can't understand why. If the car's electrical system is up to par and nothing is wrong, and as long as you run a big enough cable, there's no reason that anything shouldn't work. If it worked fine with the battery up front, and now it doesn't with it in the back, something isn't right with the relocation related wiring.
What size wire did you use, where is it hooked to, clean surface? Factory body to engine ground still in place?
With those specs can it be a problem???
and to add its a brand new red top optima, i tried 4 diff batteries and they all did the same thing. and a brand new alternater that is charging good.
