setting ride height up front
I got a set of new strange SA up front and hopefully my springs will be here thursday, problem is were shootin for a track visit friday. Where would be a good place to start with compression the springs to obtain stock ride height...and as im typing this, i just realized i forgot to measure what it was before i tore everything off
. Any help would be great guys. I measuer I htink the amount of lower threads showing, and write that right on the shock, and they what the front wheel well gap was.
I htink it was around 3 5/8 was 27inch. but its huge on wheel size, weight of your car and coils. But if you see the pic I htink you could get a idea were you set you parts up.
If nothing else, at least grease the contact point of the spring to the collar... that will make it alot easier.
Ride height, if you can get it to about 26 to 26.5 that should work. Measure the gap of the wheel well to the ground, with the tape measure running strait thru the wheel (center it on the wheel, not actually thru the wheel itself). That's about 1/2 an inch or so lower the stock, and usually is a good starting point.
Set both sides the same height, with the driver in the car, to keep things weighted correctly as well.
My wife suprised me with the shocks for fathers day....so no bearing kit was purchased, but A++++ for thought and effort lol
If ya were local I'd just come over and do it... but MO isn't anywhere near central CT... so sorry on that.
