Drag Racing Tech
Needing some susp. advice..
Old Jun 25, 2011 | 03:23 PM
mr_biscuitz's Avatar
Default Needing some susp. advice..
Took car to track last friday and ran a few ok passes, 9.73@128, 9.56@142 and like a 10.01 spinning. All passes were made on 14-15lbs leaving on 5lbs. Last night went back and ran a couple more 9.5 passes. Best pass was a 6.005 to 1/8th @122 with a 1.42 60ft. Anyways my question, it seems like my suspension is unloading as soon as the tires come down and then its hooking again. Basic info on my susp. is the rear shocks are double afco with stock cut springs, and the fronts are qa1 single adj. with 275lb springs. with a 295/50 radial. Rear shocks where bought from Madman and Co so if you guys want to chime in that would be awesome. Rears were at 21 on rebound and 12 on compression and the fronts were all the way loose. Thanks in advance guys for the tips.
Old Jun 25, 2011 | 04:00 PM
MADMAN's Avatar
LS1Tech Sponsor
Send me some video so we can see what the car is doing.
__________________
www.madmanandcoracing.com
225-343-9029
