How bad are heavy wheels?
I know there isn't an exact answer to this, just wondering if anyone has experience running with heavier wheels, compared to stock or lighter wheels?
Only way to know the diff is to weigh them.
In a perfect world where you got perfect traction from each tire/rim setup, just the spinning weight alone would make you slower. How much will depend on the individual car set up.
For you, if your running a M6, don't expect to set any records.
Gotta get drag wheels man. I shaved off roughly 70 lbs. going from 18"s to 15"s.
I also know why.... It goes back to a basic engineering equation: I= rMr^2
I- mass moment of inertia, the energy required to rotate any object
r- (greek letter rho) a constant based on the shape of the object
M- mass of the object
r- Radius..... note that it is the radius squared
What does all that mean? The heavier your rotating mass, and (more importantly) the farther that mass is from the point of rotation, the more energy is required to both accelerate it and decelerate it....
Thus smaller/lighter tires and wheels, can be accelerated much easier, requiring less energy to do it. Even if the tread diameter remains the same, a smaller/lighter wheel helps significantly, you're bringing the mass down and reducing the radius.
this applies to all cars, not just for drag racing.
It is of my opinion that every car is different, especially when you go from manufacture to manufacture, chassis to chassis etc etc. You wont really know until you run the car and thats still assuming you can get the same amount of traction given the difference in tire which 99.9999% of the time your not so there goes another varible.
The way I look at it is that you should go as light as you possibly can without endangering your safety and as long as you can enjoy it, that is all that matters. That goes for valve train, rotating assembly, rims/tires, drivetrain....
