Drag Racing Tech
mini tubbed 4th gens.
Old 09-21-2011, 04:50 PM
  #41
Ego Killer's Avatar
Any pics of your interior panels?
Old 09-21-2011, 10:10 PM
  #42
carlos64030's Avatar
I haven't gotten around to doing anything with them yet. I plan on doing something totally custom with the panels pretty soon. As you can see though, they don't look too bad as they are right now considering they haven't been trimmed or anything.
The following users liked this post:
kyphur (06-04-2021)
Old 03-16-2012, 11:33 AM
  #43
Bradlyj8Z28's Avatar
Nice work people! Any more put there?
Old 03-21-2012, 09:48 PM
  #44
Race your car!
JL ws-6's Avatar
I will have to put some pictures of mine up.. need to take some pic's when I stop by the shop.
Old 03-24-2012, 09:12 PM
  #45
Outlaw666's Avatar
WAITING!!!!
And sub'ing lol
Old 03-24-2012, 10:17 PM
  #46
KING Z28 HAWK's Avatar
Nice work guys! Anybody have a write up?
Old 03-24-2012, 11:38 PM
  #47
DopeFedZ's Avatar
Old 11-04-2014, 11:11 AM
  #48
NitrousLS408's Avatar
so if i want to be able to Tuck a 275/60-15 drag slick what would be required.
I know wolfe tubs, i also run offset LCA with original mounting location.
and AFCO coil overs.
Would the rear end need narrowed or just rims with different offset, would frame need notching, ect
Old 11-04-2014, 10:10 PM
  #49
zssman's Avatar
You can tuck a 275/60/15 pro, on a 10" wheel, with just a narrowed rear.
Old 11-05-2014, 01:28 AM
  #50
Camaro396's Avatar
You can tuck a 275/60 with stock rear suspension. I used to run them on my car slammed down.
Old 12-17-2015, 10:35 AM
  #51
WMSuperSport's Avatar
I also use them. I just rolled the fenders, cut the bump stops off, and hammered the inside of the fender and they fit fine with a 7.5" Back space wheel
Old 12-17-2015, 11:25 AM
  #52
srs bzns's Avatar
Obviously you can keep the rear panels, but looks like the seat belts are missing. No chance on keeping the seat belts?
I'm currently running 325/30/19 on 19x12 with no mini tubs but tires still scrub pretty good sometimes and its going to get worse this year with the additional power so i have been looking into minitubs more
Old 12-18-2015, 07:42 AM
  #53
RENE'S RAGE's Avatar
What's the bs on the 12" rim?
What all did you have to do to get it to fit?
Old 12-18-2015, 07:50 AM
  #54
Race your car!
JL ws-6's Avatar
To get the 15x12 I put in which have a 4.5 inch backspace we took 6.5 inches off both sides of the rear, moved the control arms inwards on the chassis and rear, put a wishbone in as the panhard was not able to stay, we ended up cutting 1/2 way into the spring perches so the coil overs went inside the frame rails and are mounted to a cross bar that's attached to the rear portion of the cage. 18192 Hoosier 29.5 tire on them.
Old 12-18-2015, 08:03 AM
  #55
srs bzns's Avatar
The 12" wheels are OEM c6 Z wheels.
The offset is +59.
It took a bit of work. You absolutely have to have tubular LCAs, adjustable pan hard bar and I strongly recommend on car cause every MM adjustment is needed, and I would say you can not "slam" the car. Mine is lowered but conservatively. Then you have to take a hammer to the front of the fender well and roll the lip of the quarter panel as flat as possible. You should also cut the bump stop area completely off. I didn't cut enough and that is where I am scrubbing a little bit. I also used a 5mm spacer just to get a little better inner clearance
69PrimedC10 (09-20-2021)
Old 12-18-2015, 09:30 AM
  #56
I figured they were some factory vette wheels. Thought you might have to do more to make them fit. Don't know how tall and wide a 325/30/19 is.
I've seen pics of JL's car and what he did to get them to fit.
Old 12-18-2015, 10:11 AM
  #57
srs bzns's Avatar
My car is in the body shop now since its winter up here. I might get it back this weekend. I'll snap some pictures once I get it back in the garage at home
Old 12-19-2015, 09:18 AM
  #58
Nice build with a TON of work. Is it possible to shorten the panhard and just mount it towards the center? Or is that pretty much useless?
Is 15x12 considered a big tire car?
Can we get some pics of the setup? Especially how you mounted the shocks please?
Killer setup
Old 12-19-2015, 06:30 PM
  #59
millerpa's Avatar
Wolfes mini tub kit
mwc narrowed 3 per side. 15x10 29x10.5 biggest tire i have ran
full interior, stealth box, sub, amp, 5 gallon ice box. street car
Attached Thumbnails mini tubbed 4th gens.-943596_375446519239458_1325529109_n.jpg   mini tubbed 4th gens.-149335_493301300787312_577075939_n.jpg   mini tubbed 4th gens.-1526471_492389897545119_1500858462_n.jpg
Old 12-19-2015, 06:53 PM
  #60
Race your car!
JL ws-6's Avatar
Killer setup
I would not call this a big tire setup it's more a true 10.5 tire type setup.
Here's a picture I have handy:
Quick Reply: mini tubbed 4th gens.
