Drag Racing Tech
what rpm limit?
Old Aug 2, 2011 | 08:12 PM
+badss+'s Avatar
Default what rpm limit?
i have a 94k mile 2002 camaro ss ls1 i have hptuners what is a safe rpm limit when running at the track right now it seems to be at 6200 just wondering.
Old Aug 2, 2011 | 10:24 PM
z28241's Avatar
well u can command it to be @ 6200 but with the stall and speed it MAY carry (run out) a few more 100 rpms after that b4 the actual shift..even with a shift kit...
BTW ..u didnt say if u have a specific cam that has a certain power band that it likes to peak at so the question is a little broad..
Old Aug 2, 2011 | 11:07 PM
+badss+'s Avatar
motor is stock, but have a fmvb 4l80e and s60 with 3.73 oh and my stall is a 3200.
Old Aug 2, 2011 | 11:08 PM
+badss+'s Avatar
forgot lol got tsp 1 7/8 LT, 3 in. ory,p&p tb.
Old Aug 3, 2011 | 11:33 PM
Black 99 Bird's Avatar
Probably don't want to spin those old stock springs past 6200.
Old Aug 4, 2011 | 08:46 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I'd be replacing springs before touching the limiter and when you push it, it generally supposed to be a few hundred RPM's more. Some out there have pushed further but have swapped out rod bolts. I would research the GEN III Internal section for more. You should get a good idea. IMO I think the stock cam is already topped out and unless the motor needs it, its just beating on it. But again, thats just my opinion.
Old Aug 4, 2011 | 01:18 PM
+badss+'s Avatar
yeah i'm building cash to do a cam swap and nitrous, so it will all be swapped out when i do it. so ill just leave it alone for now thanks guys for responses.
