Drag Racing Tech
First time dragracing.. 8/12
Old Aug 8, 2011 | 07:58 PM
ripgtp97's Avatar
Default First time dragracing.. 8/12
So i'm headed to the strip for the first time on friday. i've done some reading but wanted to know if anybody else had some good tips?
ALSO, i have a plug in my rear tire, should this still be okay to drag on and burnout on?
Old Aug 9, 2011 | 10:50 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Check the stickies, as they have a bunch of good info.
On a plugged tire, its got the positive and negative. If you have any other options (swapping tires front to back, running a buddys set of slicks, etc) it would be a little safer.
Derek
Old Aug 12, 2011 | 11:14 PM
ripgtp97's Avatar
Sooo i'm back from my first trip.. had 3 runs all at 13.5 trapping 105 mph.
my reaction times are a little slow for sure, besides that thouogh, are these numbers low for my mods? I have 2.73 gears as well keep in mind.
What rear tire pressure do you run to on street tires?? (nittor 555R)
Old Aug 12, 2011 | 11:27 PM
1Bad97WS-6's Avatar
What did the rest of your time slip look like. I have 273s also I hate them I have the stock stall. Tonight on 275x50x15 M/T DR's my car slowed up.
Old Aug 12, 2011 | 11:30 PM
blk99sleekbeak's Avatar
m6 or a4? what was the DA? What was you 60'?
I would think the car should atleast be in the high 12's if your m6 and cut a decent 60' but since it has 2.73's im guessing its an a4 and should be a little quicker. Get some gears and a converter in it(if my a4 assumption is correct) and go back.
Old Aug 13, 2011 | 10:06 AM
ripgtp97's Avatar
Looking up the DA it was 1415, my first pass i don't care, it was a 13.7 first time on track.. the next three were all 13.5
Best time:
RT: .341
60' 2.117
1/8 8.852
1/4 13.504 @ 105.37
It is an A4 with stock converter on 273's with 275 tires up front and 315's in the rear putting 334hp to the ground
I still feel like I should be in the high 12's?
Old Aug 13, 2011 | 12:27 PM
WheelsUp84z's Avatar
Thats pretty good times for bolt ons with 2.73 gears.
Old Aug 13, 2011 | 12:50 PM
gears and a converter should be your new best friend
Old Aug 13, 2011 | 04:53 PM
1Bad97WS-6's Avatar
I went 8.62@84mph and 13.23@106mph with a 2.03 60ft. Mods in my sig. The DA for me that day was only +199ft.. Get some seat time and times should improve. Do you leave TC on or off if your car has it..Where do you leave it at D or OD
Old Aug 13, 2011 | 10:14 PM
ripgtp97's Avatar
It's in D the whole time, no traction control on this car I can leave the line at a little higher RPM for sure as I"m not spinning off the line at all right now.
Even still guys with 2.73s such as yourself with less mods are faster than my car by a decent amount, just bothered by what I have into it with not much back
Old Aug 14, 2011 | 10:00 AM
1Bad97WS-6's Avatar
I have seen my best results leaving off Idle and leaving it in OD. For some reason my car is faster in OD instead D..
Old Aug 14, 2011 | 10:31 AM
ripgtp97's Avatar
that might make sense actually, by my guess by putting it in OD it causes it to go through the gears quicker. By being in D i BARELY get into 3rd by the time i cross the line.. take a listen:
http://www.youtube.com/watch?v=hBIHa79KENY
Old Aug 14, 2011 | 12:47 PM
1Bad97WS-6's Avatar
My car shifts in to 3rd right at the finish line. I still had my stock 245x50x16 and stock snowflake wheels. My car only put down 309 HP to the wheels. This fridaynight I added 275x50x15 DR's and skinnys on the front and my car slowed up. Then I put the stock wheels on the back and it pickup .15 and 1 mph..
Old Aug 14, 2011 | 12:50 PM
ripgtp97's Avatar
well then, why are you running 3 tenths faster than me! if im mistake you don't heave headers or an ls6 intake??
Old Aug 14, 2011 | 02:39 PM
1Bad97WS-6's Avatar
I don't have LT's but my car came from the Factory with the LS6 intake. I have all the Free Mods and I had weight reduction. Spare tire and jack and I had my front sway bar off and brackets.. That's 52 pounds Here is what my time slip looked like..
RT-0.55
60ft-2.033
330ft-5.66
660ft-8.62
MPH-84.09
1000ft 11.12
1/4---13.23
MPH--106.11
Old Aug 14, 2011 | 02:42 PM
ripgtp97's Avatar
Right. i missed that 2002 in your sig ha
Old Aug 14, 2011 | 02:49 PM
1Bad97WS-6's Avatar
It could be the DA and track prep. I have only ran 1/4 mile one time.
