Drag Racing Tech
rear coilover pics ...
Old Aug 11, 2011 | 08:30 PM
chevelledave's Avatar
Default rear coilover pics ...
putting rear afco dbl adjustables on the car ...i want to put a adjustable coil over bracket on the housing in the stock location ...anybody got pics ...how did it work out ???the shock is a stock mount style on the top
Old Aug 18, 2011 | 10:03 PM
well it appears that no one has done mod ,,,HUH ..well i went ahead and cut the factory shock mounts off ...took a set of auto fab coil over mounts and changed the throat depth about 3/4 deeper to [ut the mount in close proximity to the original stud length...the reason behind this mod is so I can use my Afco stock mount shocks with the car lowered added about 3 inches of additional shock travel length ...
Old Aug 19, 2011 | 07:13 AM
HioSSilver's Avatar
We did this years ago but no pics. We used the factory mounting location and spaced the shock out a little to keep the spring perch off the housing tube. The guy sold the car and we never really got it sorted out, but it seemed to do ok othe than poopy qa1 shocks.
Old Aug 19, 2011 | 05:40 PM
Damn digi cam is givin me grief ...heres some pics from last night
Attached Thumbnails rear coilover pics ...-agent-orange-8-18-2011-139.jpg   rear coilover pics ...-agent-orange-8-18-2011-140.jpg   rear coilover pics ...-agent-orange-8-18-2011-141.jpg   rear coilover pics ...-agent-orange-8-18-2011-143.jpg   rear coilover pics ...-agent-orange-8-18-2011-145.jpg
Old Aug 20, 2011 | 07:39 AM
Firehawk441's Avatar
I just saw this thread.
I mounted coilovers in the stock locations. I welded a reinforcement plate in the upper spring pocket. Then bolted a "U" bracket through the stock upper location. Bolted another "U" bracket on the lower mount on the rear. They've been on the car for 6-7 years.
Old Aug 20, 2011 | 10:09 AM
Yeah I couldnt use the lower mount shocks were close to bottoming out ...car is lowered 2 inches over the tire ...so i needed away to adjust shock length ..and I plan on dropping it another inch ...but I got to modify the floor its hitting the torque arm right now...
Old Aug 20, 2011 | 10:12 AM
Josh@KY-Turbo's Avatar
Getting reaady to do it myself. I will post some pics up when its finished.
Old Aug 20, 2011 | 12:29 PM
Reject's Avatar
very nice. looks to not be able to move side to side welded up to the lca bracket
Old Aug 21, 2011 | 01:36 AM
havent welded em on yet ..just mocked up ..I will be tieing them into the control arm mount and probably tie em in side to side ,,,will post more pics when its done ...
