need some burnout advice!
i realize with more practice and experience i would pic up on this but i need some ideas! when doing my pre stage burn out more often than not one tire spins more than the other, sometimes i do an awesome burn out, but other times it ain't so great, the better the burn out usually the better the run, i even sometimes find myself letting off before i want to because the car is turning sideways! what does the car need or what do i need to learn? thanks
is the car an auto or MN6? i believe you have an auto. in any case, linelocks are VERY good for quick easy burnouts. well worth the investment. many of the sponsers have them in stock. also, check to see if your posi is going out. it sounds like it. those clutches dont last forever. also if you are an auto, do the burnout in 2nd gear and keep the rpms up. in fact, that works well in an mn6 car too. lastly, make sure both tires get wet equally well before the burnout. lastly keep those rpms UP and DONT be affraid!
Originally Posted by 02SSZ7D
i've heard some goys put an air bag in the rears passenger side or is that for bad *** modded cars only?, or can i do the same thing with setting my rear hals differently?
air bag isnt worth it. your car isnt loading the suspension hard enough to need it. it is mostly manual tranny guys that run them. your car WILL turn as you have a posi rear. one side will always spin more than the other side. unless you have a locking rear that is natural. if your rear starts "walking" to the left side during a burn out, then simply turn the steering wheel the OPPOSITE direction and it will continue burning the tires and not moving around. as for milage on your car, if you are hammering it with DR or et streets, it doesnt matter how little miles you have. anyone could easily start to burn up a posi unit with sticky tires and a decent track in a matter of a few runs. remember there are clutches in a posi rear that will ALWAYS start to give up. if you are gonna stay interested in drag racing, look to thunder racing or otherr sponsers that sell a line lock. it is well worth it.
also i used to live in punta gorda (and you might remember me from sffba) but i have since moved to tampa and should be at some BMP nights this year. def at the bigger fbody/badrap meets!
