Cheeseburger Grudge Match Race
Stippy17
00' Trans Am
56k Miles
Driver - 5'6" & 155lbs
Engine & Drivetrain
Tuned by Ed Hutchins From Virginia Speed
227cc Stage II CNC Ported 59cc Patriot Heads
202 Dual Valve Springs
Comp Cams 7.4 Pushrods
LS7 Lifters
.581/.592 Comp Cams XER 224/230 Cam
LS6 Oil Pump
Double Roller Timing Chain
LS6 Intake Manifold
Ported & Polished Throttle Body
SVO 30lb Injectors
SLP Lid w/ K&N Air Filter
NGK TR-55 Plugs
MSD 8.5mm Ignition Wires
1 3/4" Pacesetter Headers
3" Texas Speed Y Pipe
3" Corsa Catback w/ No Muffler
Yank SS3600 Stall Converter
Built 4L65E Transmission
3.42 Gears w/ Zexel Torsion Carrier
Suspension & Wheels
Kenny Brown Double Diamond Subrame Connectors - Welded In
SLP Strut Tower Brace
UMI Tunned Mounted Adjustable Torque Arm (Set at -2.5)
UMI Solid Lower Control Arms
UMI LCA Relocation Brackets
UMI Solid Panhard Bar
Stock 56k Struts/Springs/Shocks
Summit Fast Five Drag Wheels (All 4)
275/50/15 Mickey Thompson ET Street Drag Radials (Rear)
165/80/15's (Front)
- Last year my car ran a best of 11.76 @ 114.8 in good DA. I didnt have the UMI Relocation Brackets yet, and was still running on a stock torque arm. This year I added those along with a line loc. Ive only made it to the track once this year, but the car has ran a best of 11.89 @ 113.9 in horrible DA. My 60ft has improved so I expect a high 11.6x-low 11.7x in good DA this year.
Z28Drifter348
98' Z28
94k Miles
Driver - 6'0" & 200lbs
Engine & Drivetrain
(Needs tuned before we race)
Trick Flow 220CC CNC Ported 64cc Heads
Dual 160lb Valve Springs
TFS 7.500 Chromoloy Pushrods
Stock Lifters
.595/.598 Comp Cams .232/.234 Cam
GM Performance Oil Pump
New Stock Replacement Timing Chain
LS1 Intake (Plans to swap a LS6 on before race)
Stock Throttle Body (Plans to Port/Polish or swap a 90mm on before race)
F.A.S.T 39lb Injectors
E3 Plugs
BBK 1 7/8" Headers
BBK 3" Y Pipe
Stock Catback w/ No Muffler
Rev Max Stage 3 4000 Stall Converter
Stock Transmission
Empire Drive Line Driveshaft
Suspension & Wheels
UMI Subrame Connectors - Welded In
UMI Tunned Mounted Adjustable Torque Arm (Set at -4)
Stock 94k Front Struts/Springs
GM Performance Rear Springs/KYB AGX Adjustable Shocks
Stock Z28 Wheels (All 4)
26/10.5/16 Mickey Thompson Bias Ply's (Rear)
245/50/16's (Front)
- Last year Kurt's car was almost completely stock down to the 2.73 gears. I believe his best run was around 13.5 @ 106. Over the course of the last few months he has made the car what it is now, and within a few more weeks his build should be complete enough to have this grudge match.
So the question is: Who will win, and by how much? I have my guess.
Before the race he wants to upgrade to an LS6 Intake, and a stock ported throttle body or 90mm tb, and he still needs tuned. Before the race I want to add an underdrive pulley. I left my dyno #'s out, because he hasnt dynoed his car yet, and frankly drag racing isnt all about dyno #'s.
Im sure if I added whp #'s to this thread we would get more responses, but I want people to base their opinion on the mods and complete setups. Neither of these cars are or ever will be dyno queens.
On a side note Kurt is supposed to be dynoing/tuning his car very soon. I'm curious to how the outcome is going to come out. I have ordered my UD Pulley..just waiting for it to come in now.
http://www.streetfire.net/video/civi...ang_209021.htm
On a side note I'm still waiting on my ud pulley. The crank bolt is on back order unfortunately. :-( Should be shipping out to me by the end of the week tho.
Winner gets a free UMI T-shirt, UMI windshield banner (if they want it) and a $25.00 Visa gift card I will send you.
Good luck guys! Let me know who wins
Is that crank hp or whp?
