weight transfer at launch questions
I cut 1.60-1.62 on 26" QTP bias plys and 1.64-1.65 on 28" MT ET street DR's
When the car launches it bring the left front up twists and tucks the right rear tire in the wheel well, on a nitrous launch of course its twice as bad. Ive tried tighting up the right rear shock but it either makes it where it doesnt hook up or not enough where it still puts the weight on the right rear.
The car has
QA1 12 ways on all 4 corners
BMR ADJ Torque Arm
BMR Torque arm relocation transmission crossmember
UMI 2 point subframe connectors
6 point rollbar
No front sway bar
Factory rear sway bar
3700lb Race weight
Is the factory rear sway bar my problem? The car is still a street car and I dont really want to run the Dragbar, would the heavier duty one help?
The car has
BMR ADJ Torque Arm
6 point rollbar
No front sway bar
3700lb Race weight
Spohn makes a heavier then stock rear bar if I recall it had issues hitting the QA1 shocks.
There are people here better then I to answer this but getting the car to leave straight is half off the equation.
https://ls1tech.com/forums/eastern-m...ay-new-pb.html this is a few years old but basically what I was dealing with.
Sound like Ill have to look into a drag bar. Its odd because I didnt have this problem last year and the only thing that has changed is I relocated my battery to the Right rear spare tire well. I would've never imagined it would throw it that far off.
I know a few guys who used to class race fox body mustangs and they had a minimum weight limit for the class. What they did is put everything light weight on the car and added ballast since it was a class requirement and then the weight transfer would be insane. The they had the ability to put ballast where they wanted to.
Before -
http://www.youtube.com/watch?v=SBV9bvEZrwM
After -
http://www.youtube.com/watch?v=SuhQkj2DCis
