Drag Racing Tech
Car sits to high.
Old Sep 24, 2011 | 08:56 PM
SmokedOutZ28's Avatar
Originally Posted by TurboStangJON
Here's my car on 275's! I'd just take the spring isolator out like others have said. My car has the spring isolator out an also 1 coil cut off of the stock spring. For future reference, cars often won't hook after lowering because the lower control arm angle changed along with other angles. If you lower it any further than the spring isolator mod you'll need to get some sort of lower control arm relocation bracket, a adjustable panhard (to center the rearend), and a adjustable torque arm (to correct pinion angle). This is about as low as you can go with a 12 bolt otherwise the rearend hits the tank.
Off topic but where did you find those LCA relocation brackets? My UMI ones are maxed out.
Old Sep 25, 2011 | 03:33 PM
TurboStangJON's Avatar
TRZ built them for me. It's one of their brackets they use on their fab rearends that was modified to fit in my control arm bracket. They don't make a universal set so they are not available for purchase. Mainly because the bracket sits inside the existing bracket and the aluminum control arm bushing had to be narrowed.
Old Sep 25, 2011 | 08:17 PM
Thanks for the heads up & Info I need to find someone locally who can help me with that.
