Drag Racing Tech
power needed to drop 1 sec in the 1/8th?
Old Sep 18, 2011 | 10:12 PM
bad6as's Avatar
Default power needed to drop 1 sec in the 1/8th?
Been 6.1 in the 1/8th at 3200lbs how much more power would it take to go say a 5.2?
I remember hearing 10hp is good for .1 but I don't think that is correct any more.
Old Sep 18, 2011 | 10:51 PM
ProTreeRacing's Avatar
Need more info. what kinda 60? mph?
Old Sep 18, 2011 | 10:53 PM
bad6as's Avatar
1.45-1.55 120mph
Old Sep 18, 2011 | 11:16 PM
03supercobra's Avatar
Originally Posted by bad6as
1.45-1.55 120mph
Alot with that 60ft, and you'd be looking at more MPH than that.
Old Sep 19, 2011 | 05:49 AM
bad6as's Avatar
That's. What the car does whn it runs a 6.1
Old Sep 19, 2011 | 06:25 AM
BlackScreaminMachine's Avatar
Internet Mechanic
10 hp for a MPH and 1 tenth in the 60 foot was generally 2 tenths in the ET. But thats when your talking a 3800 pound Fbody make stock power running somewhere in the 13's. Can't really use that logic when your far faster.
6.1 is good for 9.4x 1/4 conversion and 5.2 your talking BOTTOM 8's and to run that sort of power is going to take a killer 1/8th mile suspension setup, more weight out of the car a **** ton more power.
What the final HP # that you need is anyone's guess but I can tell you that it much more then your thinking.
Start searching for cars similar to yours and see what set ups running bottom 8's that have a compariable 1/8th time. That is what I would do, especially since there not as many examples out there compared to a F-body.
Old Sep 19, 2011 | 07:59 AM
fuel's Avatar
450hp to run a 5.2
Old Sep 19, 2011 | 08:32 AM
87silverbullet's Avatar
Originally Posted by fuel
450hp to run a 5.2
On a go-kart, maybe.
Old Sep 19, 2011 | 09:16 AM
ATwelveSec02Z28's Avatar
450hp to run a 5.2
Maybe an additional 450HP....
Old Sep 19, 2011 | 09:25 AM
tim99ws6's Avatar
he might have the mph to get to low 5s with an extra 450 to the tire, but without a 1.2x 60', it aint happening.
Old Sep 19, 2011 | 09:32 AM
Internet Mechanic
Just throwing it out there, some people been working real hard here and I think it may speak for itself. I am not where near this level so in the end I hope you find a way to get the result your looking for.
https://ls1tech.com/forums/eastern-m...smith-gbr.html
Old Sep 19, 2011 | 09:35 AM
thunderstruck507's Avatar
A friend's fox runs a BBC that makes quad digits on motor and gets hit with a 300+hp nitrous hit to run high 4s.
Recently the car got faster, best pass ever:
http://www.youtube.com/watch?v=jWVsG4BxU9s
60' 1.15
330' 3.12
1/8 mile 4.75
1/8 mph 151mph
Old Sep 19, 2011 | 10:17 AM
Fireball's Avatar
thats what I'm thinking...
it takes a ton of power to overcome a bad 60ft to run a low et.
hell...I went 154 mph on a 5.0 pass with a lazy 1.37 60 ft
Old Sep 19, 2011 | 06:05 PM
fuel's Avatar
what a extra 800 hp......
Old Sep 19, 2011 | 08:28 PM
yea i bet your looking at another 300 hp at minumim
you get that 60 down to a 1.30 or better your already down near a 5.7ish
Old Sep 19, 2011 | 08:33 PM
bad6as's Avatar
i know the 60ft needs work.
the 1.45 6.11 115 was on 14psi
im hoping with getting the 60ft down to a low 1.30 high 1.29 and 10 more lbs boost i can knock off that .9. i would be super super super happy with a 5.19 but not counting on that. my cages is only good for a 5.30
Old Sep 20, 2011 | 07:25 AM
fuel's Avatar
i ment 450 on top of what he has now
Old Sep 20, 2011 | 08:56 AM
Fbodyjunkie06's Avatar
Your gonna need about 1300 rwhp and 3200 rw to run a 5.20@135+
Old Sep 20, 2011 | 09:15 AM
ShiznityZ28's Avatar
we run about 6.0 on motor and 4.9 on nitrous about 400-500 hp worth of juice. But its probably more hp needed our 6.0 on motor is held back by convertor/gear setup for nitrous so my guess would be 500 hp. but if you can get more out of the 6.1 by getting that 60' down you may be able to get away with less "additional" hp .
Old Sep 20, 2011 | 09:39 AM
bad6as's Avatar
Time will tell. I'm hoping to make 1100 flywheel. So it is what it is. Just trying to make the best of it
