Drag Racing Tech
help me 60ft
Old Sep 25, 2011 | 12:32 AM
spook99maro's Avatar
Default help me 60ft
Ok went to the track today and best i have got is a flat 1.9 60. I guess I'll start with mods.
umi drag bar - set neutral atm
umi short trq arm - set at what umi sent it (forget to buy the angle finder)
umi lca and relo - in lowest hole
comp engineering drag shocks - set on 50/50
front sway delete
9" with 4.11
hoosier qtp 26 x 9.50 16s on stock z28 rims
motor mods in sig
best pass was 19psi cold off the limiter at 6200
60- 1.9
1/8th- 8.484 84.4mph
1/4- 13.140 107.6mph
5900 da
after that dropped pressure to 14psi cold off the limiter at 6200. Damn timing system jipped me of my 60 ft. Also backed out of it as I kinda got scared at the floaty and wandering feeling of the low pressure slick. (First time ever on a slick)
60- IDK
1/8th- 8.426 82.37mph
1/4- 13.150 106.29mph
5900 da
I guess I need some pointers on order to adjust suspension or suggestions on where to go from here.
Old Sep 25, 2011 | 10:22 PM
Played with the car again today and had some great results.
13psi cold
5000 launch
60- 1.781
1/8th- 8.232 84.82
1/4- 12.839 107.92
da- 5700
Any idea if adjusting anything can net a better 60 with a bolt on car. Its pretty much full weight with the exception of air, egr, spare tire/ jack, and a pin on sonoco.
Old Sep 26, 2011 | 02:48 AM
Black 99 Bird's Avatar
Is it spinning or bogging?
Old Sep 26, 2011 | 02:53 AM
lemons12's Avatar
Everything matches perfectly. Sure its not the da holding you back?
Old Sep 26, 2011 | 06:09 PM
The 12.80 was great. It just barely barked em off the line and hooked great.
The da is definately holding 1/4 back idk on 60 as im not a pro lol. All in all I was pretty happy with it. Was just curios about adjusting suspension to help squeeze some more time as I just bolted everything on basically lol
Old Sep 26, 2011 | 06:56 PM
lemons12's Avatar
Da kills everything... All your times match up.
Old Sep 26, 2011 | 06:59 PM
Ya i figured I wouldnt get much better than that with the da. Drag times corrected says 11.9 at 116 so im pretty happy
Old Sep 27, 2011 | 01:54 PM
tektrans's Avatar
Damn 6 speeds...............
Old Sep 27, 2011 | 03:08 PM
SLP IROC-Z's Avatar
what are you running for a clutch?
Old Sep 27, 2011 | 03:13 PM
Lol ya damn 6 speeds are to much fun
I'm running a monster lvl 3. Damn thing still bites hard with almost 23k on it.
