Will it hook?
Subframe connectors
lower control arm relocation brackets
aftermarket lower control arms
UMI TQ arm and TQ arm relocation
Sphoon 25mm rear sway bar
Will it hook well being lowered with the Eibachs? I plan on leaving pretty hard if it will hook up. Just curious on your thoughts.
There is a "sweet spot" but when you start making cam only power it really becomes a on/off switch.
You should be able to put up an ok time, just do not expect that this is the best the car can do. Also I hope you have line lock as with those tires its really needed to get them heated. Another issue i learned long ago with that tire.
3k - hooked and bogged 2.0x 60 ft.
3.5k - hooked and bogged 1.9x 60 ft
4k - broke lose and spun to 60 ft a little 1.79 60 ft, 7.671 at 93.3
4.5k - huge burnout and lower pressure to 15 psi. hooked hard and broke the driveshaft
Best pass previous to today was with the 10 bolt at 7.95 at 93 so I was happy where the times where going. I believe with a launch around 5k will net a good 60ft and a solid 7.5. Now I have to save up for a driveshaft.
