Drag Racing Tech
My 418 ci MOZEZ engine
Old Oct 3, 2011 | 04:49 PM
DBN's Avatar
DBN
Default My 418 ci MOZEZ engine
My new engine is finally ready for the dyno. I should have some numbers by next tuesday.
Old Oct 3, 2011 | 04:51 PM
Tunink's Avatar
Ooooo... Shiney.
What did that run you roughly?
Old Oct 3, 2011 | 05:53 PM
Firehawk441's Avatar
The wait is finallly over.
Eric builds a fine engine. I'm sure you won't be disappointed.
Old Oct 3, 2011 | 06:11 PM
DBN's Avatar
DBN
Originally Posted by Tunink
Ooooo... Shiney.
PM sent.
Old Oct 3, 2011 | 06:18 PM
JL ws-6's Avatar
Race your car!
Ooooo... Shiney.
Probably more then you can buy a 588 alum bbc for I'd guess...
Nice looking piece of hardware. Good luck with it!
Old Oct 3, 2011 | 07:07 PM
fuel's Avatar
wow cant wait to here....
Old Oct 3, 2011 | 07:26 PM
Zmg00camaross's Avatar
I think I would want to know how much it cost but idk lol, Cant wait for some numbers how high you plan to spin it?
Old Oct 3, 2011 | 07:31 PM
SSPerformance's Avatar
any ******** can go fast with a bbc
Old Oct 3, 2011 | 09:39 PM
DBN's Avatar
DBN
Probably spin it over 9k.
Old Oct 3, 2011 | 09:45 PM
That is what I figured very nice. should be a stout combo and propel that vette
Old Oct 4, 2011 | 11:57 AM
BES Stroked Nova's Avatar
or maybe someone that dont have the budget. Think my next motor might be a BBC.
Old Oct 4, 2011 | 05:29 PM
Sideways_S13's Avatar
Old Oct 4, 2011 | 06:20 PM
JL ws-6's Avatar
Race your car!
It's not a matter of a budget. It's a simple reliability at X amount of power equation for me.
I'd just rather spend 25 grand on a motor I know will stay together at the power level I want, then put something together that will have a substantially higher maintenance schedule.
Fwiw I call staying together, 200 passes. Doing that with an ls based engine that's making in excess of 1200 at the tires... I think the answer is going to be no.
Old Oct 4, 2011 | 06:50 PM
Wnts2Go10O's Avatar
where?
nice motor
Old Oct 4, 2011 | 07:05 PM
DBN's Avatar
DBN
Originally Posted by Wnts2Go10O
where?
nice motor
The dyno that we are planning use is in Harrisonburg, VA
Old Oct 4, 2011 | 07:32 PM
any more info bore/stroke/compression ?
Old Oct 5, 2011 | 06:17 AM
DBN's Avatar
DBN
4.185 bore, 3.800 stroke, a lot of compression.
Old Oct 5, 2011 | 07:18 AM
built408's Avatar
Reason for going smaller cubes?
Old Oct 5, 2011 | 10:26 AM
DBN's Avatar
DBN
A few reasons. I got a great deal on the Callies Magnum XL crankshaft. Also, there is a weight break in the LSX all motor class if you are under 420 ci. My C5 has an IRS rear suspension which although it works well, does not hook up like a straight axle car does. The smaller cube engine will make less torque than a larger cubic inch engine, therefore I should not increase the problem that I already have of getting the car off the line withough spinning the tires.
Old Oct 5, 2011 | 10:33 AM
ATVracr's Avatar
Nice !
What trans are you using?
