Drag Racing Tech
Whats typical gain going to 15x3.5 skinnies and 15x10 rears?
Old 10-12-2011, 03:11 AM
Restricted User
z99ls1's Avatar
Originally Posted by custm2500
It is not ricer math. It is been shown many times over and you are the first person to claim it is ricer math. It is virtualy a garentee.
Like your improvements show there are plenty of other feet to make improvments that lower your e.t. but the first 60 have the largerst effect on your et generaly.
No your way off. It is rule of thumb that .1 in your 60ft is worth .2 at the end of the track. This is very acurate and I've tested it to be very close. .3-.5 is wayyyyyyy off.
Old 10-12-2011, 04:42 AM
Benny Tocamelo's Avatar
That's exactly what I picked up when I switched to bigs and skinnies, .1 better 60ft and .2 on the long end.
Old 10-12-2011, 07:11 AM
Ph.D. in HUBRIS
custm2500's Avatar
I thought I had seen .3-.4 a few times from people. Apparently I am mistaken.
Point still remains if you can get it to hook and drop your 60ft. it will help more at the end then most other small changes you can make.
Old 10-12-2011, 09:56 AM
senicalj4579's Avatar
Originally Posted by djfury05
Senical I will most likely be going back to the track this Friday again but WITH skinnies this time so we will see what happens. The weather is forecasted to be the same so I assume the DA will be very comparable.
Let us know what happens!
Originally Posted by The Guy in MY 99TA
my old setup didnt run any more than .05 faster from 17" ws6 wheels w/ 315 nittos out back to 15x3.5" drag lites up front w/ radials on the front and 15x8s on the back w/ 26x10.5 et streets.
Now thats a big weight difference right there. Do you have both da's so we can compair them? Just face value I would have to guess that the da was lower when you had the 17s.
Can we have the da so we can see what was going on?
Old 10-12-2011, 10:03 AM
Its pretty much pointless to say what you gained from going from street setup to drag setup if there isnt a da to compair. I have heard general rule of thumb is every 1000' difference in da is.1 but I have had MUCH different results with my car. In just about every case it seems my car gains around .1 for every 500-700 drop in da.
If my car gains .1 with another 800 da reduction and I gain .1 for skinnies that puts my time at 11.718 which is pretty good I would think.
Only one way to find out I guess lol
Old 10-12-2011, 10:48 AM
djfury05's Avatar
Were you running with the air filter out of the car senical? If not you can always try that for a pass and see what happens.
Old 10-12-2011, 11:11 AM
No I wasnt. It was a k&n that I had just washed off with cleaner and water. I didnt even spray it with the oil. IDK if I would run with the filter out. The ssra knows how to collect things in the airbox if you know what I mean lol
Old 10-12-2011, 11:27 AM
Dirty Vegas's Avatar
Running without the air filter for a couple passes at the track should be fine. I've been meaning to pull mine out, but it still looks brand new since I never street drive my car.
Old 10-12-2011, 11:49 AM
AChotrod's Avatar
I usually pick up about .1 and 1mph by pulling the filter
Old 10-12-2011, 02:37 PM
Sorry dude I don't get too concerned with what the DA is. My car does run pretty consistent times when I do hit the track but my car mostly sees the streets.
Point is you will benefit from swapping to a drag set up whether its a .1 or .3
Get'em on and post up your results!
Old 10-12-2011, 04:45 PM
Photochop's Avatar
Yep thats the pretty standard rule of thumb
Old 10-14-2011, 07:51 AM
  #32
IH8FORD's Avatar
Me and JonCR96Z did a wheel swap at the track.without going into all the details someone look up thethread he started and post it in here I'm on my phone and can't get the link. The title is like new best weird results. But we swaped the wheels at the track and picked up MPH and almost no ET. Maybe a couple hundeths
Old 10-14-2011, 09:18 AM
  #33
Must be this one...https://ls1tech.com/forums/drag-raci...lts-weird.html
Old 10-14-2011, 09:29 AM
  #34
Seems like most gain consistancy over anything.
Thats alot of weight loss off rotating wheels and I would have thought the results would be night and day. Whats up with weight loss off the wheels x 4? That dosent seem realistic at all from what I have seen.
Old 10-14-2011, 10:40 AM
  #35
IH8FORD's Avatar
I don't understand your question. If your asking if there was a 15-20 weight drop per wheeelgoing fromthe 17" WS6 wheels to the Draglites and bias plys. Then the answer is yes. 60 lbs of weight off of rotating mass at a minumum.
  #36
sweetbmxrider's Avatar
If you go from a radial tire setup to a bias ply drag setup, you could lose mph but et better. There's variables with everything too. You may not be at the limit of your current wheel/tire setup but could improve with a drag setup. So gains can be skewed this way and someone might see a few tenths while another might only see 1 tenth.
Old 10-14-2011, 11:38 AM
  #37
djfury05's Avatar
well its been raining here the past few days so its not looking like its going to be some good DA again.. around 1000 probably but I will still let you know what happens Senical
Old 10-14-2011, 12:06 PM
  #38
I was just saying that the theory of every 1lb of weight loss off rotational mass = 4lbs dosent really seem to add up compaired to the results im seeing here. If it were true then the results should be night and day just from switching to lighter wheels+tires.
Old 10-14-2011, 12:32 PM
  #39
Most wheels and tires aren't that much lighter. I've been doing a lot of research before I buy a new setup for my jalopy. My stock 5 spoke 16 inch Camaro wheels should weigh between 19-20lbs a piece, so we'll call it 80 total. My 255/50/16 ET Street Radials weigh around 29lbs a piece, and my front tires are some cheapo Falken 235/55/16's that are probably around 35lbs each. 208 total lbs in wheels/tires. New combo -
Hoosier Drag Fronts - 11lbs per 22lbs total
Hoosier Drag Radials - 24lbs per 48lbs total
Weld RTS Fronts - 10.2lbs per 20.4lbs total
Weld RTS Rears 15x8 - 13.49lbs per 27lbs total
Total new wheels and tires - 117.4
Which saves 90.6 lbs and should be worth a tenth.
Your other gains would come from less rolling resistance due to the narrower front wheels. As far as rotational vs. static weight, it doesn't really matter. You're only really losing 22lbs from the drive axle wheels and tires. If you wanna multiply that x4 =88lbs it would come up with your tenth that way as well. Removing unsprung weight would make more of a difference than rotational. Hope it helps you make a decision.
Old 10-14-2011, 12:46 PM
  #40
djfury05's Avatar
Are those Falkens filled with concrete holy ****
Quick Reply: Whats typical gain going to 15x3.5 skinnies and 15x10 rears?
