Any suggestions to my launch (vid inside)
Cam only
6Spd
TDP Clutch
QP 9" Narrowed 6"
non adjustable Lower Control Arms
adjustable ta
SF connectors
all other suspension stock!
running a 4.56 gear with 28 10.5 mt slick
leaving at around 6K on 2step
it seemed to be hooking pretty solid, I just feel it should 60 foot alot better than a 1.6x
Ive cut numerous 1.4x's in my old setup cam only firehawk with 3.42's and 26" slicks!
Any suggestions or does it seem like its leaving ok!!!
Thanks guys!
Oh also dont mind my slow shifting lol, had to bleed on the clutch some it had a little air in it!!!
http://www.youtube.com/watch?v=M9TQixwvWbg
All of the energy from the clutch dump went into mashing the wheel down on the tire instead of lifting the front so the car did not appear to transfer weight very well and it unloaded the back and spun.
I would suggest more tire pressure to see if that helps! Good Luck on the next outing.
N2
N2
they said it was lifting the fronts about the heighth of a soda can....
N2
http://www.youtube.com/watch?v=a0Z2GGoQGTw
