First N2o pass with the A3 and almost wrecked
Started of with instant wheel spin and shot left got totally off the gas straightened it out, got it going and was flying until about 1000ft then it was like an ice rink. If you look real close you can see the tail lights start to sway then a cloud of smoke and it got real scary. Wonder what it would have ran on a clean pass with a 1.4 60ft. Cant really see how bad it was in the vid but here it is.
http://www.youtube.com/watch?v=G9Ti5YqcFTk
RT .511
60ft. 1.875
330. 4.888
1/8th 7.317
MPH 101.82
1000ft 9.407
1/4 11.264
MPH 118.56
If I am wrong, please correct me but it seems like you knew the car was not recovering but wanted to know the 1/4 mi ET more then worrying about you or the other driver. Now granted, some of it can be the track, could be the pavement temp, could fluids that have spilled but seems to me is that you pushed it and it scared you.
I'll check the vid when I get home but I forgot what type of tire you are running. So maybe its a good time to refresh everyone on what the set up is.
I expect you will figure it out, and probably will do it soon, just don't want you to get hurt.
The nitrous pass was the last pass of the night and it broke loose I recovered and then it was going great until i puked coolant all over the back tires. Its not the cars first time on spray just the first time with the new trans. It has never done that on the top end. I also took out the 200 jets and went with a 150shot.
The nitrous pass was the last pass of the night and it broke loose I recovered and then it was going great until i puked coolant all over the back tires. Its not the cars first time on spray just the first time with the new trans. It has never done that on the top end. I also took out the 200 just and went with a 150shot.
I would be working on the first 330 feet and then worry bout the 1/4.
I am sure others will have an opinion, mine comes froma guy much smarter then me but helped me to not just know how something works, but why and when it does not, what do you do to fix it.
So let us know what happens.
The main prob was the 2 gallons of coolant that I lost on the big end from the heater hose fitting coming out of the water pump.
The 60 sucked on the spray pass since it blew the tires but that wasnt the main problem. The big end was.
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
