opinion on gear swap.
That may help a good deal. The car sounds like a lot of fun.
If you're thinking about the 4.10 vs 3.73, I'd try splitting it, try a 3.89/3.90 depending on what rear you have.
Seems to be a happy spot... I tried the 4.10 with my old 402 motor, swapped to 3.73 and it seemed to be a little too much. I had a converter in the car that was about 4% on the top end for slippage with roughly 600 rw with the nitrous on fwiw, and the car was going about 142 to 143 depending on the day/weather/track. 3350 lbs.
If that setup was still together I would have tried getting the converter to about 5% on the top end and loosen it up on the bottom a little, or put the 4.10, or a 3.90 back into it after I had gotten it down to about 3000. That would have probably gotten about as much out of it as I could without adding more power.
In that case I would put the 4.11 in the car and if you have to, you could always put a 29 inch tall tire on if you find the car running out of gear.
You have a 12 bolt I assume with the 4 series right? Just want to confirm we're not talking about wasting time with a factory rear.
Ps posi and 456 gearset will be forsale soon if anyones interested pm me.
