Weight of your bird
Then I added a roll bar and N2o system and took out a a bunch of stuff and now have full tubular suspension and Im at 3590. WTF?????? lol
In general NON Formula T/A's and WS.6's had more luxurious options and the Head light assembly (including fog lights) are heavier. The majority if not all are T-top (all but Formulas), and some Camaro it was a better chance of a hard top. Camaros had a non power Attenna vs Powered and not sure if they had a "Monsoon" type stereo system avalible.
My car was a NON-ws.6 T/A but I can tell you I had every option but the 6 disc changer and WS.6 spec option.
Options are going to vary from car to car but in reality, getting it lower is what matters most in the race. The car and driver weight.
-front bumper support
-All ac stuff
-no catback
-15" wheels
-no rear seats
-no windshield washer resavoir
-bunch of other odds and ends
I would have to guess 3500 with me in it.
1999 Trans Am
Hardtop conversion
Strange brakes front and rear
Kirkey drivers seat only
UMI K-member
Removed AC, Radio, Airbags, Bumper supports, Wipers, & ABS
Speedglass front and rear <--- done after the above posted weight
Mini tubs w/ Wolfe spring mounts & Afco springs <--- done after the above posted weight
Madman torque arm, control arms, panhard, & manual rack <--- done after the above posted weight
PA racing LCA's <--- done after the above posted weight
VFN 5" Sloped Hood <--- done after the above posted weight
Cut out rear metal behind tubs, removed all airbag & radio related wiring, firewall insulation, & misc brackets <--- done after the above posted weight
Car has
6 pt MS cage
MS frame connectors
BMR Drag Bar
Door Bars
All lights(still functioning)
Stock fuel tank
Full weight battery
Burkhart front bumper support
This will give me 120 lbs of ballast to move wherever the chassis wants it (min weight for what I want to do with a bbc is 3000)
I will have all factory body panels on the car, with the exception of the hood... it's not a cheap thing to do but it's doable.
I will put pictures up when it's done... not really alot to show at this point other then what's cut out... it will be alot more meaningful once it's back together and people can see what is there, and how the removed material was braced/replaced, where needed.
