Drag Racing Tech
Racecraft k-member and spohn solid motor mts.
Old Nov 18, 2011 | 08:01 PM
1nastyss's Avatar
Default Racecraft k-member and spohn solid motor mts.
Im looking at going with the racecraft front chromoly k-member , upper/lower a-arms...anyways, i want to run the spohn solid motor mounts, do u guys know if they will bolt up, did a search , couldnt find any info
Old Nov 19, 2011 | 01:55 AM
TurboStangJON's Avatar
I could not find an answer to this question when I went with Racecrafts entire front suspension. I thought it would cost more to buy their K-member setup for motor mount stands then add the Spohn ones. Plus I think that buy the time you added the stands it would probably end up weighing about the same as anyone elses K-member. Mark at Racecraft actually talked me into doing away with motor mounts.
Old Nov 19, 2011 | 07:46 AM
TNTaddict's Avatar
Yep 100% sure
Old Nov 19, 2011 | 08:39 AM
1nastyss's Avatar
Originally Posted by TNTaddict
Yep 100% sure
Thanks alot buddy
