Drag Racing Tech
? on mounting stroud chute to the wolfe mount
Old Nov 21, 2011 | 01:10 PM
WheelsUp84z's Avatar
Default ? on mounting stroud chute to the wolfe mount
Well looking at the wolfe mount and the stroud chute i have, they are both flat surfaces with no holes in them. I'm not really sure as to how the two should mount together. I'm assuming the metal plate on the inside of "outer" bag needs to be bolted to the mount, does this mean i have to cut holes in the bag to get the bolts passed through? Figured I'd ask before I cut holes in a perfecty good and new chute bag.
Old Nov 21, 2011 | 04:03 PM
Dan / Wolfe Race Craft's Avatar
Remove the parachute from the pack. Take the aluminum plate out of the pack. Center it up on the mount and drill holes in the corners for the 6 3/32 bolts that we supply. Then put the aluminum plate back in the parachute pack. You can just thread the bolts thru the pack or cut slits in the pack where the holes are.
Old Nov 21, 2011 | 09:20 PM
Thanks, i ended up calling Madman (where I bought the part from) and they hooked me up with the info.
