Drag Racing Tech
how is your 2step installed
Old Nov 24, 2011 | 08:41 AM
boosteddragon's Avatar
Default how is your 2step installed
...is the...."?"
Old Nov 24, 2011 | 10:48 AM
Asian LSX's Avatar
Mine is located by where the ABS used to be next to the line lock and hooked up to an on/off switch.
Old Nov 24, 2011 | 10:52 AM
RsSean's Avatar
Mine mounted next to the master cylinder, it is wired to the clutch switch, clutch pedal down it is on working. Clutch is out the 2 step is off. It has it ups and downs
Old Nov 24, 2011 | 11:48 AM
Tally TransAm's Avatar
mounted on the drivers side shock tower and wired into a switched ground on the lower clutch switch
Old Nov 25, 2011 | 11:49 AM
nocooler's Avatar
Clutch switch with a momentary inline. Push in the clutch, hit the button and it's on the 2 step - release either and the 2 step deactivates.
Old Nov 25, 2011 | 03:36 PM
TurboStangJON's Avatar
I have mine mounted where the stock PCM use to sit an it goes off of when I have the transbrake activated. I wish it was inside the car like my PCM is but the connectors are too large to fit through a hole. Other than that I like my MSD 2-Step.
http://www.youtube.com/watch?v=Ecz_R7sXxjk
