how do you a 5 point harness, side straps
what about the twoside straps that go to the floor? do i drill a hole with eyebolt? do i have to weld something? pics?
We have the bolt-on crotch strap brackets in stock and the best deal on them. Made of lightweight chromemoly tube and powdercoated finish. Give us a call when you're ready!
The crotch strap I had attached to the bottom of the kirkey seat, which was solid bolted right to the floor on the back studs. Not right by the standards.... but it never failed tech at 6 different tracks, fwiw.
The attaching bracket should be mounted in the same direction as the pull of the belt to spread the load across the webbing as much as possible. You can put a little bent in the bracket between the slot for the webbing and the bolt hole to make this work better in some situations.
