Drag Racing Tech
2012 Updates.
Old Dec 6, 2011 | 01:08 AM
lt1camaroman93's Avatar
Default 2012 Updates.
Figured I'd share my winter adventures. Nothing major, just a new turbo locations and moving to air to water instead of the air to air. Thinking about putting a real mini-tub in it and pulling the tires in 3/4" a side. Moving along pretty well, I'm ~5 days into the project.
2011 setup
The start to 2012 "Mock up stage"
Making weld on bungs and "tabs" for IC mounting
Time to cut!!!!! Just rough cut for now, I'll be cleaning it all up down the road.
Fabbing up the new front structure.
Working on turbo mounting
IC is mounted. I will be re-making the upper tire bar. Don't like how its not centered and at a goofy angle.
Starting in on the cold side
Interior cold side. I almost made it all without having to use any silicon couplers. Ended up having to use one in the pipe that goes from the IC to the TB. It would not come out of the car in one piece... I tried. Angry.
Down pipe fab
Don't mind the body line, fender is fully bolted on.
Old Dec 6, 2011 | 01:21 AM
Just wanted to see what twin large frames would look like.
Old Dec 6, 2011 | 07:29 AM
fuel's Avatar
wow......nice work,and car
Old Dec 6, 2011 | 12:46 PM
AChotrod's Avatar
Looks great Jay! You gonna go twins or were ya just messing around?
Old Dec 6, 2011 | 01:35 PM
Just playing around. Single 85. Still same ol iron block motor, so that's my limit.
Old Dec 6, 2011 | 01:42 PM
John Deere racer's Avatar
Lol those turbos are bigger than ones on my tractor ... And I have the biggest John Deere makes....
Just sick!!!!!!
Old Dec 6, 2011 | 02:08 PM
mrdragster1970's Avatar
6 & 8 Second Club
Same ?? I always ask, why go with the big *** cooler instead of going with alcohol??
That's a lot of stuff to squeeze in there just for the cooler system, plus all the weight.
Definitely some nice work going on there, looks sweet.
Old Dec 6, 2011 | 03:20 PM
I like to street drive it, also, double the fuel equals more cylinder pressure and that is something I do not need with this combo. I went the alcohol route with my other turbo car, made life easier for most things, besides oil change every four passes, lol.
Thank you!!
Old Dec 6, 2011 | 03:25 PM
WS6SP33D's Avatar
Looks great man.
Old Dec 6, 2011 | 04:00 PM
6 & 8 Second Club
I would never thought of that, when I see a monster like that, I think track only.
So since you have done the alcohol already, which makes more power, alcohol or water cooler everything being semi-similar??
I still would love to go with a Pro Charger on alcohol, but I'm too old & lazy to start over!!
Again, that build looks nice, love the workmanship & attention to detail!!
I've always wished I had that level of skill!!
Old Dec 6, 2011 | 04:18 PM
I wish I had an exact answer for you on that, but the other motor was only ever run on alcohol. All I know is that thing made STUPID power per lb of boost. 434" sbc with cfe 15* heads and 11:1. What I can tell you, is e85 does make more power than c16 with an air to air. I would bet they are very close with air to water.
Old Mar 1, 2012 | 09:46 PM
I haven't had much time to work on my car as I've been busy with a few others. Had some time to do some more cutting in the back to get it ready for the wheel tubs. Hoping the boys over at Race Engineering can squeeze me in within the next couple of weeks for the tubs and tin work. Then when I get it back in the garage I just have some small misc **** to button up then re-wire the car since the IC went where everything was mounted. Anyone want to sponsor me a turbo????? lol
Old Mar 1, 2012 | 11:14 PM
6 & 8 Second Club
What the hell tire are you putting in there???
That's a big *** tub!!!
If you have any of the big inlet pipe left, save it for me. I'm going to need some later in the spring!!!
I HOPE!!
Good luck finishing.
Old Mar 2, 2012 | 11:00 AM
I HOPE!!
Sadly, that's the O/L 10.5 tub, but its the smallest I could get. It will be cut down a good bit from there. Nothing like spending a bagillion dollars on a tub to trim it to half its size. I look forward to seeing your car this year, I've been waiting for someone to bring out a LIGHT car with a procharded bbc.
Old Mar 2, 2012 | 01:06 PM
6 & 8 Second Club
OH, makes sense, they probably sell a lot more for big tire guys, so you guys get screwed and have all the waste!!
I think the carbon tubs for mine were ~$600 when the alum tubs were all beat up??
Don't forget, I will be running legal, so I will probably weigh 2610-2620.
I would love to see a 540", F-3 on alcohol, 2100-2200lb, big tire car.
That thing would take off like a jet!!
Old Mar 2, 2012 | 02:21 PM
kline454's Avatar
Damn!!! Looking good man!
Old Mar 3, 2012 | 07:57 AM
White.Lightning's Avatar
Looks great
Could you vband the one pipe that requires the silicone coupler?
Old Mar 3, 2012 | 06:06 PM
Originally Posted by White.Lightning
Looks great
Nope, you can't get it out of the car then. I tried, lol.
Old Mar 4, 2012 | 12:06 AM
Outlaw666's Avatar
nice...where did you get that exhaust ring?
Old Mar 4, 2012 | 12:22 AM
Made it in house. There isn't much that I'll buy, I'm a cheap *** so I try and make as much stuff as possible.
