Kirkey Seats , 9" Installed..
There was thread started awhile back on installing the Pro Drag seats in late models..Some people made their own mounts or mounted the seats on the original seats racks..
I started by measureing the seats on the stock mounts and they ended up way to high for me .( I'm 6' tall)..Then I started to use the Kirkey mounts and they just wouldn't mount without adding something to them to make those fit..
So I decided to mount them directly to the floor and this was much easier and looked alot cleaner installed IMOP..The seats are super comfortable and took almost 60 lbs out of the car..
Also installed a Moser 9" with one of their Aluminum , spooled 35 splined center sections..This was another bolt in without any problems and I really don't think that my car will have any rearend issues for some time to come.
Also thanks to Jay Billingsley for making a very simple ABS delete block that fit like a glove...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://www.soslow.cz28.com/slide_shows/Trans_Am_Pictures/P3140003.jpg)
![](http://www.soslow.cz28.com/slide_shows/Trans_Am_Pictures/P3140004.jpg)
![](http://www.soslow.cz28.com/slide_shows/Trans_Am_Pictures/P3090003.jpg)
![](http://www.soslow.cz28.com/slide_shows/Trans_Am_Pictures/P3090004.jpg)
![](http://www.soslow.cz28.com/slide_shows/Trans_Am_Pictures/P3090001.jpg)
Originally Posted by Kent1
Those are nice seats. How much do the Kirley's weigh themselves and did you just bolt them to the floor with no adapter-is that correct?
I'm getting a custom built seat from Kirkey. I talked to Kevin and he told me what measurements to take. I'm a big guy at 6'4" @ 300+ pounds. He assured me more leg room, which is my majory concern besides safety. My stock leather seats push me forward an additional 3 inches over the Kirkey Drag Seats. I plan on mounting mine low, and having my buddy Shane at Induction build me a custom welded mount. The passenger seat will be a standard Econo Drag with an 18" width.
The weight savings of Kirkey vs. stock is unbelievable! My best guess is atleast 60lbs of dead weight removed from the car. Lighter is faster, even I'm on a diet and exercise regemine to get some dead weight off of me!!!
Good looking job on your car, and that 9 inch rearend looks killer!!!
How did you mount your seats to the ground? I want to mount my seats as low as possible, and as far back as possible, this should help with comfort issues. I have a set of Kirkey Pro Street seats with covers coming from Jegs, and am looking for max leg room.
Did you weld up homemade brackets? Do the seats come with some sort of bracket with bolt holes? I can get anything welded or fabricated, so this is no major concern.
