Cages and Kids?????
Obviously don't turn the boost up or drop the 300 shot of nitrous but a padded cage will not have any ill effect on having kids in the car.
My 3year old loves "race cars!" And is always wanting to "go fast" which Is cruising 55mph with a loose converter and no overdrive (3k rpm)
I'm sure my car needs at the least a 4point roll bar, but i refuse to put one in if it means my youngin' isnt safe to ride in the car any longer.
Think about it, and car seat has a 5point harness..
That cage, if you get in an accident, is going to be a nightmare to try to get the kid otu of the car, and then what if there's a fire?
What if the car is side swiped, and you get pushed into a guard rail, you can't get out thru your door car's against a guard rail and the car that pushed you into it is on the other door... and a fire breaks out? You going to be able to climb thru the cage to get him out thru a window?
What if you get in an accident and the jaws of life are needed, and then they have to spend 5 more minutes trying to get to the kid becuase the cage is in the way and his bleeding doesn't get stopped in time?
Absolutely not a safe idea in any way, padding or not, helmet or not, etc.etc.
If you have a 2nd front seat in the car (I assume you do) and when he's big enough to get buckled into that with the 2nd 5 pt harness, then that's a different story. I'd still make the kid wear a helmet. Kid will probably love that anyway.
Back seat, or a child seat in a car with a cage, no way period.
SOO TRUE!!! This is what I tell my buddies when they wanna go cruz..Tooo many "What Ifs" and a Life is way more important to me than a 15min joy ride!
If someone wants a cage in a car thats going to be a daily driver the cage designer can make it less intrusive so all seats can be used, even in a two door car. Takes a little more work for them but they can do it.
