Drag Racing Tech
Advice For New Drag Racer
Old Dec 23, 2011 | 12:28 PM
Greekey's Avatar
Default Advice For New Drag Racer
Guys, I got some questions. I'm finally starting to take my trans am to the drag strip in the spring. How exactly do you guys launch your m6's? Do you guys dump the clutch or let out slowly? What determines at what rpm's you should launch at? Also, what determines at what rpm's you should shift at?
Old Dec 23, 2011 | 01:14 PM
blk/slvr02ss's Avatar
U nned to slip the cluthch and the RPM u need well u have to see were your car comes out the best w/ out tire spin and i would have the car dynoed to see the peak HP to see were u would shift your car !!!
Old Dec 23, 2011 | 01:38 PM
deerslayinrednek's Avatar
stock 10-bolt? if so definitely slip the clutch....What tires will you be running?
Old Dec 23, 2011 | 01:59 PM
arioch's Avatar
i hold it at about 2K rpm's then slip the clutch till i feel it hook then full throttle. Shift at the top of the RPM band without hitting the rev limiter.
Of course i haven't tried it with the new power since im on a stock fried clutch still....
Old Dec 23, 2011 | 07:24 PM
midwestjunk's Avatar
I had a heads/cam nitrous set up with my 6-speed. on my 10.20 pass i side stepped the clutch at 6,100rpm and pinned it to the floor with the nitrous on. it 60fted 1.40 with the wheels up. all depends on your tire and rearend gear. i had a 28x10.50 hoosier slick and a 4.10 gear. if your tryin this on stock 17's with drag radials i personally had to slip the clutch at maybe 3,500 and not put the pedal down all the way in 1st gear. on the nitrous i couldnt even spray till 2nd gear on a 17" rim. car 60fts 1.80 on a 17" BFG drag radial.
I shift my heads/cam ls1 with stock bottom end at 6,800-6,900rpm. the car made power all the way to that, but shifting any higher scares me on a stock motor. i played it safe and kept it under 7 grand. if you post a dyno sheet i'm sure we can help you determine where your car makes power and where it falls off to determine launch rpm and shift points.
Old Dec 24, 2011 | 08:18 AM
autokraft's Avatar
Dont listen to those guys. Floor that bitch til its bouncing off the rev limiter and dump the clutch! You gotta give up the baby food sometime! Dont be scared!
Old Dec 24, 2011 | 11:30 AM
1_bad_TA's Avatar
10 bolt?
Old Dec 24, 2011 | 05:14 PM
coolmanvette75's Avatar
On my 17 inch dr's I dump it at 4500-5k on the 10 bolt
Old Dec 25, 2011 | 10:21 AM
608kZ28's Avatar
LOL!! i actually saw someone do that
Old Dec 25, 2011 | 07:03 PM
black and pink z28's Avatar
If u have a stock 10 bolt and a sticky tire ur not going to be able to leave hard I know this cuz I have broke one and a stock drive shaft too
Old Dec 25, 2011 | 07:10 PM
Really I broke a 10 bolt and a drive shift on a street tire 10 bolt was on the street and the dive shaft was at the track leaving at 2500 at the track on street tires
Old Dec 28, 2011 | 09:28 AM
joblo1978's Avatar
Your particular setup will determine how hard you can launch. Most important things being tire, gear ratio, weight transfer, and weight. Ideally you want to get a little bit of tire spin out of the hole to keep the RPM's up.
Old Dec 28, 2011 | 11:20 AM
chasgiv3's Avatar
I see the glass 10bolt being a maraca in the near future!!!!....LOL
