Drag Racing Tech
No Torque Arm Setup - with ET Streets
Old Mar 17, 2004 | 08:29 AM
GainesvilleLS1's Avatar
Originally Posted by RyanJ
Thats how Madman recommends using the Z bars...interesting. So with the Lakewood setup, what is to stop your rear from moving around?
Well if you look at it, its boxed. It can't go anywhere unless the lower bracket snaps. Think how a ladder bar holds the rear end in place, very similar. Your reaction was the same as mine when I first installed it and hucked the TA. I was imagining the springs popping out, and the whole rearend spinning and ripping the back of the car off I was really hoping my logic was correct.
With the original setup, right out of the box, the Lakewood is NOT strong enough to handle this job. You need to beef it up, and you need to weld the brackets in. Once I did that, it got a whole lot better.
One thought I had while installing, I think I could actually use a longer lower bar and weld it straight to the chassis in front of the LCA (there is room!). That would give me a longer lower bar, and act more like a true 4 bar setup, but it would have to be a strong bar.
Old Mar 17, 2004 | 08:33 AM
Guys forgive me if I dont respond in the next 3 days! I'll be back online once I settle in this weekend.
Moving from FL to Vermont... who does this sort of thing?
Old Mar 17, 2004 | 10:12 AM
gator's 99TA's Avatar
why in the world leave florida for vermont??? lol.
Old Mar 20, 2004 | 12:58 PM
<staring out window looking at snow> I'm asking myself that question right now....
Old Mar 20, 2004 | 01:06 PM
GrannySShifting's Avatar
Are therre any cars runnign somethign like this that are launching good?
Old Mar 20, 2004 | 01:19 PM
I dont know of any others. But mine is launching good, just got some bad drivetrain problems. I wish all was high and tight on my car, and I could throw out some accurate results. I'll do what I can. Nearest track is in Canada, 1.5 hours from here... and my car is staying in FL until the salt trucks stop. Gonna be awhile. Peace!
Old Mar 22, 2004 | 04:06 PM
mongse's Avatar
I ruin the end of films...
The first gen SSM bars were similar to what you did. You could run them w/o a torque arm, but they would hit pretty hard (like someone else said). It made running a 9" rear end MUCH easier since you didn't have to make a torque arm mount.
Old Apr 5, 2004 | 12:10 AM
LIL SS's Avatar
Moderator
Wondering if you have been to the track again yet?
I was also wondering if you would mind posting some more detailed pictures and how you set it up (construction wise)..
Old Apr 5, 2004 | 12:36 AM
LIL SS's Avatar
Moderator
Also, what did Spohn charge for the custom LCA's?
