Drag Racing Tech
can I remove EBCM
Old Jan 18, 2012 | 09:08 AM
beanhead's Avatar
Question can I remove EBCM
I posted in suspension and braking but got no response so i figured I'd give it a shot here. I'm ordering the SJM abs delete with line lock and the non TCS throttle cables and removing both the abs and tcs. (they dont work anyways) Can I remove the EBCM once the tcs and abs are gone? and if so what all can i remove with it?
Old Jan 20, 2012 | 03:01 AM
SJMMFGINC's Avatar
You'll be removing the ABS controller (EBCM) and bracket with our kit. TCS you can remove that also if you want. It will be just sitting on the passenger side fender as dead weight.
Old Jan 20, 2012 | 10:52 AM
sweetbmxrider's Avatar
The ebcm is the module under the dash. You can pull it out.
Old Jan 20, 2012 | 03:44 PM
RENE'S RAGE's Avatar
The EBCM can be removed, it has a few plugs on it, just unplug them.
Old Jan 23, 2012 | 04:13 PM
djfury05's Avatar
Someone post pics of what the EBCM module looks like.. my complete body and engine harness is out but and that's a lot of damn wires to look through lol.
Old Jan 29, 2012 | 10:12 AM
PRAY HRD's Avatar
also in for a pic if someone has one.....?
Old Jan 29, 2012 | 12:53 PM
I'll try and get a pic.
It is mounted on the drivers side, under the dash, it's kind of hard to see under there.
Old Jan 29, 2012 | 02:29 PM
This is the Accelerator & Servo Control Module that's mounted under the dash, driver side. It says Trottle Position Controller on it. Some people call it the EBCM module. It has some wires going to the EBCM. You can remove this also.
The EBCM is actually in the engine bay screw to the bottom of the ABS controller.
I'll get a pic of the plug that goes to the EBCM. I don't have the EBCM, sold it a long time ago.
Old Jan 29, 2012 | 03:10 PM
This is the plug for the EBCM.
Old Jan 29, 2012 | 04:14 PM
TurboStangJON's Avatar
The EBCM (Electronic Brake Control Module) is under the ABS controller on the drivers side engine bay.
Old Jan 29, 2012 | 05:09 PM
That is correct!
Old Jan 29, 2012 | 05:42 PM
PRAY HRD's Avatar
will removing any of this affect the cruise control in any way by chance?
Old Jan 29, 2012 | 05:50 PM
Good question, that, I don't know.
Old Jan 29, 2012 | 06:30 PM
beanhead's Avatar
thanks for the info and pics above... would also like to know this
Old Jan 29, 2012 | 10:04 PM
Originally Posted by RENE'S RAGE
That is correct!
Sorry I repeated what you said above I was just supporting your info since others stated it was up under the dash.
I don't think unplugging the EBCM will harm the cruise control because I can recall having cruise when it was deleted. However, I would recommend unplugging it and testing to be sure.
Old Jan 31, 2012 | 05:55 PM
I think you said it better.
I sometimes confuse people, and myself.
Old Feb 10, 2012 | 10:42 AM
armyboyatc's Avatar
This is located under the drivers side of the dash behind and up from the fuse box right? If so Im glad I read this thread because I had no idea what that thing was and was too chicken to delete it!
Old Feb 10, 2012 | 02:35 PM
Benny Tocamelo's Avatar
Has anyone weighed this, how much does it weigh?
Old Feb 10, 2012 | 02:41 PM
No, the EBCM is located in the drivers side engine bay under the ABS controller (see post #10). What you're speaking of is the Servo Control Module which is used to control the throttle in the event of a traction control situation.
