Aerospace rear brake ?
Does the caliper mount get pressed on the axle like the stock backing plate or can you just slide it over the axle. It has a cut away so you could but its also recessed in the center for what appears that the bearing can sit against it.
My single caliper had an open side so didnt need to be on before the bearing.
Also be forewarned... if they are stock type housing ends, you will need a spacer that goes inside the axle housing end between the bearing.
Deep housing ends allow for the bearing to sit completely inside, without the spacers the axle can move in and out about an 1/8" and the rotor will hit the caliper.
Excellent point. I just ran into this trying to assemble my new setup this week. deep housing ends and the bearing sat flush. When we went to bolt up, the caliper would have contacted the bracket for caliper. Thankfully, Chuck@Burkhart is taking care of me and shipped me out some spacers.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
how do I know if I have deep housing ends? My axles are the new torrino style if that helps any, moser 9 inch. Mine is the dual set-up as well but it also has a opening in the bracket so didnt know and where did you guys get the spacers. Im going to call aerospace tomorrow and see what they say.
Im asking ? cause I dont want to have to purchase two sets of bearings, any time I have had to have bearings pressed off they have been ruined. So wanted to get it right the first time.
