Drag Racing Tech
Draglite question
Old Jan 30, 2012 | 09:26 PM
skat's Avatar
Default Draglite question
I'm looking at a set of draglites in trade for my rims. They are 15x4 front with 2.5" backspace and 15x8 rear with 4.5" backspace.
I want to know how would they fit? Will they stick out? Will they work? I know I have to grind the capliers, I'm not worried bout that I just want to make sure they will work and look good.
Thanks
Old Jan 30, 2012 | 10:55 PM
TurboStangJON's Avatar
Thanks
What works and what you have probably seen on other cars is a 15x3.5 rim with 1.75 backspacing. On that note, the 15x4 fronts you're looking at will be inward compared to a 15x3.5 Draglite. I think your problem will be in the rear because I believe it takes a 15x8 with 5.5 backspacing to sit flush with the fenderwell. This means your tire will sit out an inch, look weird, and more than likely hit the fenderwell. I wouldn't buy those wheels because they will give you a headache.
Old Jan 31, 2012 | 12:49 PM
skat's Avatar
That's what I'm afraid of. After all the work to get them to fit they look stupid and stick out.
