Kooks 2" and manual rack
The #1 primary, is SO far in the say I have serious doubts if it will even clear a stock rack and steering shaft, nevermind an aftermarket rack.
The #1 primary needs to snake down towards the block more... plain and simple. Josh @ KY speed did a BIG set of headers for smkn95 on here, they were either 2 1/8 or 2 1/4 and he routed them so the headers had plenty of room around the steering shaft (wrapped them tighter to the block).
I don't know why this hasn't been fixed yet, the 1 7/8 stepped to 2 inch headers I had from kooks barely cleared the stock steering shaft, with an aftermarket rack and k member there was no way.
I don't think there's a whole bunch of people that are using any stock suspension parts, and actually need a 2 inch header, that being said, why the header wasn't built and test fit on a car with an aftermarket rack and k member I can't even start to guess.
Header primary on #1 still should be moved in on those headers though, it's not like the extra bend is going to kill them.
Every guy buying a set for a race car that's going to have a manual rack, would buy that brand/model header, no question.
But yet it hasn't happened. If someone were to offer a service, ship me your drivers side header and I will cut out the portion of the #1 primary that doesn't clear and make it swing inwards and back out, for a reasonable fee, that guy would probably make even more money. Makes me want to buy a tig welder and go buy a bunch of 1 3/4, 1 7/8 and 2 inch 90 and 45 degree prebent tubing, and a good band saw.
The #1 primary needs to snake down towards the block more... plain and simple. Josh @ KY-Turbo did a BIG set of headers for smkn95 on here, they were either 2 1/8 or 2 1/4 and he routed them so the headers had plenty of room around the steering shaft (wrapped them tighter to the block).
They were 2 1/4" primaries. Spark plug access is as good or better than manifolds. Ground clearance is as good or better than the 2" Kooks he had. Steering shaft clearance in his case is as good or better than the headers he had.
The headers you built (way the #1 was routed compared to the standard copy of the grotyohan design that pretty much every other header was based off of) were done in a way that will create more clearance hands down.
Why noone else ever did them that way, well I gave up trying to figure it out.
