Drag Racing Tech
Manual Rack
Old May 20, 2012 | 12:50 PM
  #41
TJ's Avatar
TJ
Originally Posted by 02sleeperz28
Uh, yes they do. I got mine from them through PA racing. You just need the correct part number.
factory manual rack or was it a pinto box?
Old May 20, 2012 | 11:12 PM
  #42
02sleeperz28's Avatar
Pinto style.
Old May 21, 2012 | 06:36 PM
  #43
TJ's Avatar
TJ
Pinto style.
thats what i thought. we have been discussing a converted stock rack........
Old May 21, 2012 | 06:43 PM
  #44
fucter's Avatar
In for results, wish I heard about this a couple weeks ago, could have saved about 700 dollars ( I went with power though, and turned out not to need a rack)
Old May 21, 2012 | 10:28 PM
  #45
Grr's Avatar
Grr
dont know why you would send it in and pay for it, some of us have been doing this for 10-20 years.
Unscrew the tube and cut the seal on the piston, screw it back together and put plugs in all the holes. DONE
You are only paying for the welding and grinding that you can have any local shop do or do yourself
Old May 25, 2012 | 11:34 AM
  #46
a-low's Avatar
That easy huh? Ive never seen the inside of a rack got any pics?
Old May 25, 2012 | 12:48 PM
  #47
TJ's Avatar
TJ
doing it yourself is a great idea, but for the price its convenient. i dont know anyone who would weld up, grind down and paint the rack for 149. not to mention having to drive across town to drop it off, then gas and time to pick it back up.
Old May 25, 2012 | 01:05 PM
  #48
LongIsland63SS409's Avatar
I started this thread to show a cost effect way to have a manual rack.
Since I am converting a V6 to a V8 I needed a LS1 rack for header clearence.
Most eBay racks were around $79. The manual rack conversion ends up being a very cost effective solution.
Also the spool valve is machined and welded for strength in addition to the pistons.
As I stated in a previous post the rack operates very smoothly without binding.
Mike
Old May 26, 2012 | 11:42 AM
  #49
AChotrod's Avatar
Pretty cool Ive decided to go manual just didnt want to spend the big money other places are asking. What is the benefit of buying the MWC or Madman kit over this???? If there is a real performance or weight saving its worth it! If there isnt this seems the way to go IMO.
Old May 27, 2012 | 08:10 AM
  #50
TJ's Avatar
TJ
pinto rack will be lighter, and less muscle to turn. more flexability if you custom mount it for header clearance.
Old May 31, 2012 | 08:11 PM
  #51
RENE'S RAGE's Avatar
Anyone else use this rack?
Old Jun 5, 2012 | 01:28 PM
  #52
AChotrod's Avatar
Ill be ordering on in a week or so. There is a couple options so how do I know which one to get?
Old Jun 5, 2012 | 02:25 PM
  #53
SIC LSX's Avatar
Sweet cant wait for reviews!! im interested. I like it because its cheep, keep stock turning radius, cleans up engine bay, and removes weight off front of car.
Old Jun 5, 2012 | 03:49 PM
  #54
Options?
When I ordered mine I don't remember options.
What are they so I can help you in the right direction.
Mike
Old Jun 5, 2012 | 04:52 PM
  #55
How do you know if you have the F41 or FE2, FE4, FE7 rack?
Old Jun 6, 2012 | 05:52 AM
  #56
Look at the drivers door decal for the production codes. I needed the rack for a LS motor for header clearance.
Call Rich if unsure what to order. Nice person to deal with.
I will check my invoice tonight.
Old Jun 6, 2012 | 06:34 AM
  #57
I don't have a door decal anymore.
My steering rack has 26048277 R/2 stamped on it.
Old Jun 6, 2012 | 06:43 AM
  #58
studderin's Avatar
Never checked, but dose the stock setup have bumpsteer?
heres the kit to add some adjustment on the stock rack, I found.
http://www.summitracing.com/parts/BAE-3301011/
I know some of the aftermarket rack placements do.
Old Jun 6, 2012 | 04:47 PM
  #59
O.K. when to the dealership today, they ran my VIN.
I have the FE4 suspension.
Old Jun 7, 2012 | 07:21 AM
  #60
Checked my invoice and that is the one I ordered.
Invoice part number is 3570-custom c.
Mike
