LT1 alcohol carb
I would call pro systems for a carb though, they should be able to get you one setup for what you want to do, and at least have it in the ballpark.
Is the motor set up to run alcohol, ring gap wise, etc? And I'm sure someone has already said something to you, but the oil needs alot better maintenance program as well due to the amount of fuel that gets in it. Alcohol isn't legal for all classes too, which may or may not be an issue.
My BBC is 489 inches and runs a rather small Afco radiator. never gets hot on Alcohol, does on gasoline. Runs about .3 slower on race gas.
Al 95 z28
The 3000 cfm fan and shroud, will help alot with it as well as being able to leave the pump running, fan on when the engine is not. I don't plan on running it any more then I absolutley have to, I'll tow it as much as I can within the class limitations.
There are many small blocks around here on Ron's Fuel Systems. As long as they are set up for the motor they will run just fine.
If you are interested in a injected system I would call James Monroe at KillerRons. He is the best. He gives extremely good customer service and will get you pointed in the right direction.
Ken
