Drag Racing Tech
wheel studs
Old Apr 10, 2012 | 06:00 PM
BuckaroooZ28's Avatar
Default wheel studs
at what point should i swap to 1/2'' wheels studs in the rear?
Old Apr 11, 2012 | 04:54 AM
soco80p's Avatar
The stockers can hold quite a bit of power, but if you plan on spraying it or running slicks, it won't be a bad idea to upgrade.
Old Apr 11, 2012 | 07:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Based on your mods, now. I have seen guys hitting 5-6 launches on slicks and you can see the studs bending. Its more like repeated launches will do the job. You just need to plan for it accordingly.
Old Apr 11, 2012 | 12:54 PM
black00ssFL's Avatar
I've bent my stockers with 400whp, ls7 clutch, 5500 rpm clutch dumps, on a bia ply tire. I have 1/2" studs in there now.
Old Apr 11, 2012 | 02:29 PM
blue99fbody's Avatar
i ran 12mm 3" arp wheels studs for 3 yrs @ 550-800whp with a 6spd car and hundreds of 6k rpm launches ive since upgraded to 5/8 bc i knew i was pushing the limits
Old Apr 11, 2012 | 02:42 PM
1lejohn's Avatar
12mm Arp studs here. So far no problems.
Old Apr 11, 2012 | 06:48 PM
Doug G's Avatar
One thing I've learned running a spool (even a tight posi will do it) is to check and properly torque the lugnuts on a reguler basis.
The constant working back and forth takes it's toll.
I've seen 5/8" screw-in studs break too (other side was loose so we figured that's what happened).
Old Apr 12, 2012 | 10:12 AM
Thanks for the input guys...I'm running 12mm extra long arp. ...launch@ 6000 on slicks....ill plan on upgrading soonish
Old Apr 12, 2012 | 10:14 AM
Oh and that's with a locker
Old Apr 14, 2012 | 04:27 PM
1lejohn's Avatar
Thats the key. I also use never sezze on my studs. The books tell you not to but what do they know. If you don't and change wheels often you will gall one. Just adjust you torque setting accordingly.
