Fast N/A cars
3200 stall
cam
lid
borla - hollowed out cats
asp pulley
nx 100
ect ... but nothing big..
Cam only cars fall in the same lines but when you add a cam you change so much in the suspension,tires and gearing along with needing a tuned PCM more so than a SI car. It took me over a year to get my setup that i have now playing with suspension,gearing,tires and converters. Now i have it setup and i just have to wait it out for some cold air to return later in the year. My car at local tracks runs with heads/cam cars and most can't figure out why but if you dig into the car deeper you can see i finally matched everything up and getting it to launch hard helps to without breaking anything. Just set the car up to where everything works together and everything will fall into place and don't look at other cars and start compareing them to yours because every car is different in some ways.
Get the long tubes and tuning and you should see a BIG difference in the ETs and mph. Might want to step the converter up more (YPT4000/SS 4000/3.73s) something that will work with motor and nitrous.
Coach
Thanks for all the help.
Just figure out which direction you want to take your car, then work on those goals. Reducing weight on a car is not always the first choice for everyone, some of us prefer to just add more power.
Tony
