guys with Cheetah shifters, i got a question
I went straight back and drilled the hole on the side of the trans tunnel after going 180 degrees with the cable back towards the front of car... the hole was straight tehn i used a screwdriver to kind of angle it so that the cable would lay flush against the tranny tunnel... works great...
1 Post
I drilled a hole a couple of inches back then used a 1/2" extension to elongate the hole so it didn't cut into the cable. Like others have said route the cable where the factory brake/fuel line goes so it will stay off the driveshaft. I stuck more to the drivers side of the tunnel so it would come out near the lines.
