Which front runner fits?
I plan to use the M/T 4 ply Sportsman tire.
Wid Offs Brand
3.5 1.75 Pro Star
4.0 2.25 Pro Star
4.0 2.25 Rodlite
3.5 1.75 Draglite
4.0 2.25 Draglite
5.0 3.50 Draglite
4.0 2.31 Convo Pro
Yeah, I like the Bogarts (and was going to buy them for the rear because of fit, but was given Welds) but I am going to use the difference (Bogart/Weld) to get a Fast intake. Better bang/buck.
Lynda:
Do they stick out? Flush? Inset a bit? Any current pictures?
Coach:
Thanks, that helps. I don't want to put light brakes on it, as this is still supposed to be my grocery getter
David
Tell you the true, I can't remember. BUT I believe it was the 1 3/4. I do have extended bolts on front at back. No spacers or grinding. Fit is almost perfect. Rears are 15x10 Convo Pros with 28x10.5x15. When I ordered by Moser 12-bolt I had it narrowed 1.5" on each side. Again no spacers, banging, or grinding needed. But I doubt I have much room left for the 29-30" I more than likely will be needing shortly.
David
David
Yeah, I can see where 29" would be a problem. I noticed shiny spots in the wheel wells from my 315 nitto / 11" ZR1 combo. Didn't use the BFH long enough.
