Noob 1/4 mile question...
So i went to the track after breaking in the trans and stall, with my new nittos 555r's.
I thought these where suppouse to hook as everyone told me they would!!!
My times 16.1 et with a 2.1 60//// 15.7 et 2.3 60/// And the one pass i did some what hook, i let out thinking i was gona spin made 12.6 et 1.9 60 @ 106 I dont get it, does the stall make me loose Trap speed? When stock i was at 110 trap...
Im Pissed!!!
I know I wont see much Improvement as times get a lil faster than stock, and not hoping to see 11's but atleast a low 12.
What em i doing wrong? I have to admit, its a totally different car after the stall. So if you have a stall in your ride, please shime in.
I was way more consistent with stock trans and was able to pull a 2.0 sixty 12.9 Et @ 110
next time at the track,switched to et streets & ran an 11.08@121 1.48 60'........
Edit: 38 psi is waaaaay too much.
What psi should i run at the track?...
I'll give it a try. What about launch rpm, even at 2k I spin through what it seems the whole 60.
i have gone down to 12psi with the nittos & still did not hook,but did get squirelly on the big end.
I wonder if that new trans is a bit sloppy, or if your tune needs to be gone over again. I've noticed that sometimes with a new trans, shift points will need to be adjusted, maybe it's shifting too early and costing you some MPH.
Some of your times dont even make any sense though... you did a 16.1 with a better 60 then when you ran 15.7? Are you letting off or something? I mean you must be as those times are very slow...
How are you launching the car? Brake pedal and revving the car up? Or just taking off from idle?
