Drag Racing Tech
Race Weights?
Old Jun 25, 2012 | 09:15 PM
studderin's Avatar
under 2800
Old Jun 26, 2012 | 09:49 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Race weight of 3050 with me in the car. I am 253 LBS.
Coach
Old Jun 26, 2012 | 09:36 PM
5.3LJimmy's Avatar
I have my trans am down to 2925 with me in it and I'm 210lbs. Single kirkey seat, Vfn pin on Hood, strange brakes, madman rack, speedglass f&r, minitubs, th350, 12 bolt with a spool, and hardtop conversion.
I pulled just about everything listed in the weight reduction sticky out of the car. I still have functioning headlights, door bars, and a horn for now.
Up front I have a UMI kmember with PA control arms. All the rear stuff is from Madman except the BMR drag bar.
Old Jun 26, 2012 | 09:46 PM
WhiteLTone's Avatar
thats light! how much did you end up saving by going w/ rear drag brakes and steering rack? i still have factory steering rack, column, and rear brakes. ive been considering doing the door panels and a few other things. i have ttops too and i hate them, but the 6liter conversion targa top is soo much money.
Old Jun 27, 2012 | 12:44 AM
gmtechnician's Avatar
just wondering does anyone know what these cars weight factory i have a 98 trans am
Old Jun 27, 2012 | 06:22 AM
WhiteLTone's Avatar
3400-3600 depending on options
Old Jun 27, 2012 | 10:57 AM
5.3LJimmy's Avatar
It has been a few years, so I don't remember exactly how much the brakes saved. I did all four corners at the same time and I believe it was 110-120lbs all together. This is using Strange brakes with the Racecraft front spindle that use the third gen brakes and the Racecraft manual master cylinder. Switching from power to manual steering is around 25lbs savings when you include the pump and lines.
I still have the factory door panels and steering column. All interior plastics and center console are in the car as well. I have some Ozite carpet to put in but I'm waiting to upgrade from a MS 6 point to a CM 10 point before installing it. The 2925 was with no carpet in the car.
I went to a junk yard and cut a hardtop roof panel from a 96 Camaro. I was tired of the paint bubbling on my sail panel and figured if I was going to go through the hassle of swapping it I should delete the t-tops. I used the roof panel, the door seals, and cut the metal that runs at the top edge of the door opening from the Camaro.
Old Jun 27, 2012 | 02:46 PM
chas010's Avatar
3030 with me in it.
Old Jun 27, 2012 | 07:25 PM
WhiteLTone's Avatar
Thanks 5.3Jimmy - my car has same weight reduction as you pretty much, last year 2680 w/o me in it, this year maybe about the same w/ new n2o stuff. I'll probably do door panels, wiring harness, front radiator support and front strut towers and some more trimming over the winter.
Old Aug 8, 2012 | 07:27 PM
TransAm-Z's Avatar
These low weights make me sick! I just weighed in for the first time at 3950 car weight... That was with the Drag wheels, skinnies and only 1 seat.
Daily Driver w/some weight reduction, Full cage, sub-frame con, 9" ford, 4L80E, Iron block, 50lb 91mm turbo, air/water intercooler ect... Heavy Heavy Heavy!
I think I might be able to get it down to 3700-3800 fairly easy, but beyond that is gonna cost some serious $$
Old Aug 8, 2012 | 08:29 PM
JL ws-6's Avatar
Race your car!
Lose the iron block, that's 100 lbs right there.. next time the motor's getting freshened up swap to an alum block... 4l80 is about the heaviest trans you can put in the car, so unless you really need the overdrive, I'd put a 2 speed in it and be done there, that will pull another 100 lbs out.
Alum center section for the rear end, that would save a good 40 plus. You have alot of weight you can get rid of easily if you're willing to do some parts swapping, etc. Cheap no, but there's plenty there.
I'm now looking ar 2800 with me in it, with an iron block bbc. Pic's in my rebuild thread, if you want to see what that will take.
Old Aug 8, 2012 | 09:14 PM
  #32
Zero4488's Avatar
Restricted User
Well my car with the bolt ons and 9" with a Th400 and minor weight reduction weighed 3480 with me in it...took out a lot more but added a bar, turbo, and iron block...
Old Jul 23, 2024 | 09:34 AM
  #33
Adrian Leal's Avatar
How did you get your trans am to that weight if you don't mind me asking man
