Drag Racing Tech
Going to strip for first time.
Old Aug 8, 2012 | 05:13 PM
badformulaLS1's Avatar
Default Going to strip for first time.
So this weekend I'm going to the drag strip (1/8 mile) to run my car for the first time and I have some questions about whats the best way to do things to get the best time. I'm on street tires (sumitomo htr z III 275/45/18). I know to go around the water but should I still try a small burnout or is it not necessary?
Also should I launch in D or 3? Or start in 3 and move it up to D at a certian point?
Should I launch from a certain rpm or just step on it from idle?
Any tips to avoid a ton of wheel spin?
Thanks.
Old Aug 8, 2012 | 06:05 PM
zracer323's Avatar
On street tires just do a small burnout to clean the tires off. If you have a stock tranny then just leave it in D, built tranny use 3. I would recommend trying different launch rpms but you may have to just roll into the throttle depending on trqck prep.
Btw I read the title of your thread way wrong at first lol
Old Aug 8, 2012 | 06:19 PM
LOL I did not catch that when I wrote it Thanks for the tips.
Old Aug 8, 2012 | 06:28 PM
aQuickLS1's Avatar
Yeah, I read that title wrong too.
Like said above, just to a quick burn to clean the tires off. Then play around with the launch till you figure out what works best.
Old Aug 8, 2012 | 06:41 PM
orange88ls1s-dime's Avatar
youll probably want to load the suspension a bit, try 1500 rpm then increase it till the tires start to creep. shocking them from idle might prove to be problematic. as your driving around the water box, stab the throttle for a second or 2 and that will do for burnout.
this procedure has always worked for me with real street tires
Beaudacious
Old Aug 9, 2012 | 11:01 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
With my stock 3.23 geared automatic, my best results on real street tires (stock 16" Good Years) was this:
Drive around the water and line up straight. Put the shifter in first and mat the gas to the floor just to do a quick clean off of the tires.
Would stall the car to about 900-1000 rpm an roll into the throttle (takes a little practice to see what your car will do against the tires and track prep).
I've run the shifter both in overdrive (D) and third; I have bounced the RPM high side chip on the 1-2 shift with it in D, but never in third.
Got me a best of 2.00 60 foot and 13.47 at 103.50 mph in typical Florida August weather.
Derek
Old Aug 17, 2012 | 07:04 PM
JRracing's Avatar
Put it to the floor and don't lift til you see sand or a net..
Old Aug 17, 2012 | 07:10 PM
abritton77's Avatar
Good luck......I just started myself and didnt realize how difficult it would be to cut a good light.
