No Torque Arm suspensions..
There are only a couple things that I really question though.
Now all the force the rear end sees is put on the 2 front rear controll arm bolts. What is going to happen to those mounting locations with lots of 1.5 60 foots? I don't think those mounting tabs are going to hold will they?
Now, what if you changed the location of the LCA's. Instead of using brackets welded to the UCA (Upper Controll Arm), you used longer LCA's and welded mounting brackets to the actual rear subframe.
I like the idea of a toqrue arm less suspension. Any other ideas or comments?
I'm starting to lean towards a ladder bar if I can put it in with out cutting up the floor.
